Hi all,
with the latest new component for google home i made a small (and most possibly ugly) automation to turn on my lights when an alarm rings at one of my google homes.
I guess some of you could use this too
A new sensor is needed to get the current time, therefore we need to add this to our sensors: config
sensors:
- platform: time_date
display_options:
- 'date'
- 'time_utc'
Now here comes the ugly part.
This is the needed automation
- alias: 'Alarm Clock Bedroom'
platform: template
value_template: >
{%- if states.sensor.google_home_alarm.state.split('T')[0] == states.sensor.date.state and '{}:{}'.format(*states.sensor.google_home_alarm.state.split('T')[1].split('+')[0].split(':')[:-1]) == states.sensor.time_utc.state -%}True
{%- else -%}
False
{%- endif -%}
- service: light.turn_on
entity_id: light.livingroom
data_template:
transition: 60
brightness: 255
Unfortunately the next alarm time is reported as a string and the format differs from date_time sensor. So i had to split the string myself.
Known Limitations
- Google home sets the alarm in HH:MM:SS, i only check for HH:MM, therefore the lights might turn on up to 59 seconds before the alarm rings
- UTC Date borders are not respected.
When i created this, i had 00:25 after midnight, i live in a UTC+1 timezone. Which means, the alarm date was yesterday instead of today. - Alarms do not trigger the automation when UTC Date differs from local Date
I guess this is a bug in the sensor and therefore a bug report should be opened, but for today i need some sleep. Will open it later on if this is an issue for any of you
I hope you can use this automation and feel free to add any improvements. I would really appreciate when someone could improve this.
