since 0.90.0 the Settings Tab in the UI is not working correctly for me. If I click on “General” nothing happend. I have to scroll down to see the settings. “Automation” is not working. I cant get into my Automations. I made a Video to explain. Whats happened?
This issue was reported here and also posted as an issue in Github.
The cause was determined to be the presence of the Custom_UI component. This custom component is currently incompatible with 0.90.
Remove or comment out the relevant lines from configuration.yaml
# customizer:
# custom_ui: local
Restart Home Assistant and (important!) clear your browser’s cache.
If this doesn’t eliminate the problem for you then something else is causing it.
Thanks for reply.
I already comment out customizer because of other issues. But same issue. I also have to comment out this line under frondend and then clear browser cache.
# extra_html_url:
# - /local/custom_ui/state-card-custom-ui.html
Its working again. Thanks a lot
I removed the line that was causing the problem and rebuilt it here:
You can just grab the .html files if you want to keep custom_ui enabled while we wait for a real fix.
