Still no luck on updating from 0.89.2 to 0.90
this is the System log I get
19-03-21 15:39:03 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:08 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:08 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:08 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:13 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:13 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:13 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:14 WARNING (MainThread) [hassio.homeassistant] Don't wait anymore of Home Assistant startup!
19-03-21 15:39:14 CRITICAL (MainThread) [hassio.homeassistant] HomeAssistant update fails -> rollback!
19-03-21 15:39:14 INFO (MainThread) [hassio.homeassistant] Update Home Assistant to version 0.89.2
19-03-21 15:39:14 INFO (SyncWorker_9) [hassio.docker.interface] Update Docker homeassistant/qemux86-64-homeassistant:0.90.0 to homeassistant/qemux86-64-homeassistant:0.89.2
19-03-21 15:39:14 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.89.2.
19-03-21 15:39:18 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:18 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:18 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:23 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:23 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:28 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:28 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:28 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:33 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:33 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:33 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:38 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:38 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:43 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:43 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:43 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:46 INFO (SyncWorker_9) [hassio.docker.interface] Tag image homeassistant/qemux86-64-homeassistant with version 0.89.2 as latest
19-03-21 15:39:46 INFO (SyncWorker_9) [hassio.docker.interface] Stop homeassistant/qemux86-64-homeassistant Docker application
19-03-21 15:39:48 INFO (SyncWorker_9) [hassio.docker.interface] Clean homeassistant/qemux86-64-homeassistant Docker application
19-03-21 15:39:48 INFO (SyncWorker_9) [hassio.docker.interface] Cleanup Docker images: ['homeassistant/qemux86-64-homeassistant:0.90.0']
19-03-21 15:39:48 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:48 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:48 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:49 INFO (SyncWorker_7) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.89.2
19-03-21 15:39:53 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:53 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:53 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:39:58 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:39:58 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:39:58 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:03 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:03 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:03 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:08 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:08 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:08 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:13 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:13 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:13 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:18 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:18 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:18 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:23 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:23 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:28 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:28 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:28 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:33 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:33 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:33 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:38 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:38 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:43 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:43 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:43 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:48 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:48 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:48 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:53 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:53 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:53 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:40:58 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:40:58 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:40:58 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:41:03 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:41:03 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:41:03 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:41:08 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:41:08 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:41:08 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:41:13 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:41:13 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:41:13 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:41:18 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:41:18 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:41:18 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-03-21 15:41:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-03-21 15:41:23 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-03-21 15:41:24 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-03-21 15:41:24 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/config access from a0d7b954_appdaemon3
19-03-21 15:41:24 INFO (MainThread) [hassio.api.proxy] /homeassistant/api/states access from a0d7b954_appdaemon3
19-03-21 15:41:24 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-03-21 15:41:24 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.89.2```
Any suggestion?
I have an Ubuntu server with Docker and Hassio installed in containers.
