0.91: More streaming, better Zigbee, cameras with ESPHome
Did you install Tensorflow as a docker container? Or with the pip method?
TensorFlow is included in the official docker container or through pip for venv installs. You can not use a separate TensorFlow standalone container.
You mean it’s included in the Hass.io official container? Fantastic, didn’t realize that. One less thing to worry about :slight_smile:
No, not Hass.io. Home Assistant container.
Dear,
Do you mean downloading homeassistant as container on raspbian strech or any os?
I’m very new to docker, so didn’t even know there was a separate home assistant container as separate from the hass.io container (running on ubuntu under Docker). Regardless, I found your hass.io add-on fir installing tensorflow on hass.io, and it appears to be working, or at least not throwing errors. I set it up on one camera, but I need to have someone actually walk past that camera before I can tell if it’s on or not. :slight_smile: (I set it up remotely, there’s noone home)
For some reasion 0.91.3 is not showing up as available in my Hass.io. I’m presently at 0.91.2
Anything I can do to make it show?
Wait for the hassio image to be built?
But does it normally take this long? It was released the 10th. Is there a place I can see the latest Hass.io version?
Try this
From ssh
hassio ha update --version=0.91.3
I updated to 0.91.3 a few days ago so it should be available.
No, I had it since some days, updated yesterday
Yes, I guess I could do that. Just curious what would cause it not to show up.
Unfortunately I’ll have to go back to v89. This version broke my Xiaomi_aqara component. I tried regenerating the key a few times, nothing seems to work, it just says (MainThread) [homeassistant.config] Invalid config for [xiaomi_aqara]: required key not provided @ data[‘xiaomi_aqara’][‘gateways’][1][‘mac’]. Got None. (See /config/configuration.yaml, line 21). Please check the docs at https://home-assistant.io/components/xiaomi_aqara/
As far as I’m concerned, it is configured correctly and it worked perfectly before updating to this version. Anybody else with a Xiaomi Mi Gateway experiencing the same issue?
2 Xiaomi gateways working perfectly fine on 91.3 and also tested with latest beta without issue
Thanks for confirming, I will try to play about with it, hopefully get it to work. Reverting back to v89.1 it works perfectly, when I update Home Assistant, it stops working. I have default config:
xiaomi_aqara:
discovery_retry: 5
gateways:
- mac: 7C:49:EB:xx:xx:xx
- key: **************
Not really sure what makes it break.
Xiaomi gateway works fine here on 0.91.x
Try removing the colons from the MAC address, the description of the mac option says:
The MAC address of your gateway. Needs to be formatted without “:”.
I don’t know if this changed in this version.
You don’t even need the MAC address unless you have more than one gateway.
Is anyone else having persistent issues with Yeelight?
Have tried restarting multiple times, using discovery and not, config is all up to scratch.
0.91.0 works perfectly fine and have rolled back and forth - with 0.91.4 entities appear as unavailable and I see the following error consistently:
2019-04-24 20:32:58 ERROR (MainThread) [homeassistant.components.light] yeelight: Error on device update!
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py", line 261, in _async_add_entity
    await entity.async_device_update(warning=False)
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/helpers/entity.py", line 379, in async_device_update
    await self.hass.async_add_executor_job(self.update)
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 331, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/local/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
    future.result()
  File "/usr/local/lib/python3.6/asyncio/futures.py", line 244, in result
    raise self._exception
  File "/usr/local/lib/python3.6/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.6/site-packages/homeassistant/components/yeelight/light.py", line 356, in update
    elif self.light_type == yeelight.enums.LightType.Ambient:
AttributeError: module 'yeelight' has no attribute 'enums'
