0.92.0 upgrade error - "Integration not found: introduction"
After the .92.0 upgrade upon checking the config I get this error (attachedha-config-err
What is this? How do I solve it?
Read the release notes, specifically breaking changes.
Remove introduction: from your configuration.yaml file. Apparently they forgot to adjust the default file.
From the official blog.
Introduction - The introduction integration has been removed. It used to be part of the initially created configuration but no longer served a purpose. (@balloob - #22944) (introduction docs)
Just remove the introduction component from your configuration.yaml file.
Sorted, thank you.
Thanks, should’vew looked but, not sure Iwould jave known to removed the lines.
