After upgrading Hassio v0.91n to 0.92 HA no longer loads zwave. Instead I get the following error in my log file
2019-04-26 12:29:37 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Z-Wave (import from configuration.yaml) for zwave
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/config_entries.py", line 309, in async_setup
hass, self)
File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/zwave/__init__.py", line 256, in async_setup_entry
from openzwave.option import ZWaveOption
ImportError: cannot import name 'ZWaveOption'
Never seen this before but I never made any changes to my configuration in days and each restart prior to 0.92 worked fine and did not produce such error
I apologize for being no help, but I do have a working Z-Wave with 0.92.0, so at least we know it is not a total fail.
Looking through the 0.92.0 release notes, there were a few changes to Z-Wave components, but nothing seems obviously problematic.
I did see a change that enforced formatting for the Z-Wave network key as well as a change around Boolean sensor values. So maybe go through your Z-Wave stanza in the config very carefully looking for something that might be relevant.
