Since upgrade from 0.94.3 -> 0.94.4, all my MQTT devices stopped working.
The log says
2019-06-20 12:37:21 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 111] Connection refused
2019-06-20 12:37:21 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 363, in _async_add_entity
await entity.async_added_to_hass()
File “/usr/src/homeassistant/homeassistant/components/mqtt/sensor.py”, line 108, in async_added_to_hass
await self._subscribe_topics()
File “/usr/src/homeassistant/homeassistant/components/mqtt/sensor.py”, line 170, in _subscribe_topics
‘qos’: self._config[CONF_QOS]}})
File “/usr/src/homeassistant/homeassistant/components/mqtt/subscription.py”, line 79, in async_subscribe_topics
await requested.resubscribe_if_necessary(hass, current)
File “/usr/src/homeassistant/homeassistant/components/mqtt/subscription.py”, line 40, in resubscribe_if_necessary
self.qos, self.encoding
File “/usr/src/homeassistant/homeassistant/components/mqtt/init.py”, line 382, in async_subscribe
qos, encoding)
File “/usr/src/homeassistant/homeassistant/components/mqtt/init.py”, line 742, in async_subscribe
await self._async_perform_subscription(topic, qos)
File “/usr/src/homeassistant/homeassistant/components/mqtt/init.py”, line 780, in _async_perform_subscription
_raise_on_error(result)
File “/usr/src/homeassistant/homeassistant/components/mqtt/init.py”, line 872, in _raise_on_error
‘Error talking to MQTT: {}’.format(mqtt.error_string(result_code)))
homeassistant.exceptions.HomeAssistantError: Error talking to MQTT: The client is not currently connected.
2019-06-20 12:38:01 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 111] Connection refused
2019-06-20 12:38:12 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 111] Connection refused
2019-06-20 12:38:33 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 111] Connection refused
2019-06-20 12:39:14 ERROR (MainThread) [homeassistant.components.mqtt] Failed to connect due to exception: [Errno 111] Connection refused
Manually connecting to the broker still works as with previous version
