0.94 - device_tracker and combining NMAP & OwnTracks
As part of 0.94 I understand that combining multiple tracking methods to a single entity is not supported anymore. Anybody any idea on how to solve so I still use a single entity for my presences? Inside, there is normally poor GPS signals and the NMAP picks up the devices on WiFi.
Use the Person component.
I’ve been testing this component since it was released and it sends out way too many updates on location.
I will be sitting at the office and see it trigger several times an hour that I’m at the office, even though the state hasn’t actually changed.
What device tracker are you using? If it’s a “stationary” one have you tweaked consider_home and interval_seconds?
I’m using Unifi and Ariela (GPS). Consider home and interval make no difference. The “state” changes even though the state doesn’t change. Been monitoring it and logging it in nodered since it was released. Interval and consider home don’t do anything to change the fact that I’m at work and it spams my logs that I’m at the office all day.
It would be much appreciated if you could log this as an issue!
