I tried your suggestion but it didn’t work. I might try rolling back to 94 or just live with it until I find out how to fix it. Thanks for the suggestion though, hopefully it’ll help someone else.
edit It seems there was a connection error, I set up a new WiFi SSID and connected the Aqara hub to it and it all connected again.
Of course! That makes complete sense. Thanks. Restarted the addon, hit configure, and immediately got push notifications from the Alexa app that new sensors had been picked up Thanks!
Moving into the RV world - i have had HA in my camper for a couple of years now. Here in the UK and most of europe Victron Energy Products are widely used for Solar/Charging & DC-AC inverters.
Could really do with a native integration to Victrons’ USB or Bluetooth VE-BUS. I did manage to cobble together a sensor to review voltage/amps in and out, from a log file from another 3rd party python script. But there will be many of us on here that use Victron products be it household solar/boating/campervan(RVs) and also industrial remotely monitored projects.
No, you shouldn’t need to add anything to your configuration file(s) unless you want to change one of the configuration variables to a non-default value. Just adding the account information via the Integrations page in the UI should be sufficient.
If you’re having problems it would be helpful to provide some details as to what you’re seeing or not seeing.
Make sure <config>/custom_components/life360 has been deleted. Restart HA. And if it still doesn’t work, try refreshing your browser while you’re on the Integrations page.
