Recently updated to 0.96.1 (and now 0.96.2) - I run HA inside a FreeNAS jail.
Upon trying to start I get:
Configuration invalidCHECK CONFIG
Platform not found: media_player.braviatv
And it won’t let me start until I comment out the media_player section of the config. A google suggest this is a known problem that was fixed for the release? Unless I am reading that wrong?
If it has been fixed what can I do to stop myself from having this issue?
I am seeing the following error on Home Assistant 0.104.3:
config $ more home-assistant.log|grep bravia
2020-01-30 16:33:21 INFO (SyncWorker_8) [homeassistant.loader] Loaded braviatv from homeassistant.components.braviatv
2020-01-30 16:33:25 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.braviatv
2020-01-30 16:33:25 ERROR (SyncWorker_7) [braviarc.braviarc] [W] Exception: HTTPConnectionPool(host='192.168.1.207', port=80): Max retries exceeded with url: /sony/accessControl (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x7095ac50>: Failed to establish a new connection: [Errno 111] Connection refused'))
2020-01-30 16:40:08 ERROR (SyncWorker_10) [braviarc.braviarc] Exception: HTTPConnectionPool(host='192.168.1.207', port=80): Max retries exceeded with url: /sony/system (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x70940850>: Failed to establish a new connection: [Errno 111] Connection refused'))
File "/usr/src/homeassistant/homeassistant/components/braviatv/media_player.py", line 313, in turn_on
self._braviarc.turn_on()
File "/usr/local/lib/python3.7/site-packages/braviarc/braviarc.py", line 257, in turn_on
File "/usr/local/lib/python3.7/site-packages/braviarc/braviarc.py", line 229, in get_command_code
File "/usr/local/lib/python3.7/site-packages/braviarc/braviarc.py", line 222, in _refresh_commands
2020-01-30 16:40:10 ERROR (SyncWorker_16) [braviarc.braviarc] Exception: HTTPConnectionPool(host='192.168.1.207', port=80): Max retries exceeded with url: /sony/system (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6cb2cf90>: Failed to establish a new connection: [Errno 111] Connection refused'))
config $
