0.96: Notion, updated sidebar, advanced mode
Possibly due to the changes for climate 1.0. I would check out the GitHub pr on the changes
Smartir climate had same issue and was resolved by Dev of it
I was monitoring the beta and didn’t see anything dramatically different in MQTT HVAC. Of course, all it takes is just one little change in just the right place …
Unrelated to my custom component but I just noticed i0.96.0 can’t find the toggle-lock-entity-row card. Weird. More digging to be done.
Screenshot%20from%202019-07-17%2023-28-49
Ditto. Though using CCH to hide it on tablets and for users who I don’t want to access it at all is possible. So no drama.
Nor mine. All objections dismissed.
The ability of CCH to hide it isn’t adequate IMO.
I’m really looking forward to this update (cloud fix):
really happy that the HassIO version is out so quickly too! Awesome :grin:
I’m seeing 0.96 there
I had to relead the browser page, old page must have been cached.
I stand corrected. my bad
whoooo buddy… I am not even sure where to start with this lol. This is what the config tester gives me.
I am currently running 95.4
  copying cffi/_embedding.h -> build/lib.linux-armv7l-3.7/cffi
    copying cffi/_cffi_errors.h -> build/lib.linux-armv7l-3.7/cffi
    running build_ext
    building '_cffi_backend' extension
    creating build/temp.linux-armv7l-3.7
    creating build/temp.linux-armv7l-3.7/c
    gcc -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -DTHREAD_STACK_SIZE=0x100000 -fPIC -I/usr/include/ffi -I/usr/include/libffi -I/usr/local/include/python3.7m -c c/_cffi_backend.c -o build/temp.linux-armv7l-3.7/c/_cffi_backend.o
    unable to execute 'gcc': No such file or directory
    error: command 'gcc' failed with exit status 1
    ERROR: Failed building wheel for cffi
    Running setup.py clean for cffi
    Building wheel for pycparser (setup.py): started
    Building wheel for pycparser (setup.py): finished with status 'done'
    Stored in directory: /root/.cache/pip/wheels/f2/9a/90/de94f8556265ddc9d9c8b271b0f63e57b26fb1d67a45564511
  Successfully built pycparser
  Failed to build cffi
  Installing collected packages: setuptools, wheel, pycparser, cffi
    Running setup.py install for cffi: started
      Running setup.py install for cffi: finished with status 'error'
      ERROR: Complete output from command /usr/local/bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-728nqkv3/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5sb4lqs2/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-gbqe3dil/overlay --compile:
      ERROR: unable to execute 'gcc': No such file or directory
          No working compiler found, or bogus compiler options passed to
          the compiler from Python's standard "distutils" module.  See
          the error messages above.  Likely, the problem is not related
          to CFFI but generic to the setup.py of any Python package that
          tries to compile C code.  (Hints: on OS/X 10.8, for errors about
          -mno-fused-madd see http://stackoverflow.com/questions/22313407/
          Otherwise, see https://wiki.python.org/moin/CompLangPython or
          the IRC channel #python on irc.freenode.net.)
          Trying to continue anyway.  If you are trying to install CFFI from
          a build done in a different context, you can ignore this warning.
      running install
      running build
      running build_py
      creating build
      creating build/lib.linux-armv7l-3.7
      creating build/lib.linux-armv7l-3.7/cffi
      copying cffi/ffiplatform.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/pkgconfig.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/verifier.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/lock.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/api.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/cffi_opcode.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/model.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/vengine_gen.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/recompiler.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/vengine_cpy.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/__init__.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/setuptools_ext.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/cparser.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/error.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/commontypes.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/backend_ctypes.py -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/_cffi_include.h -> build/lib.linux-armv7l-3.7/cffi
      copying cffi/parse_c_type.h -> build/lib.linux-armv7l-3.7/cffi
      running build_ext
  ERROR: Command "/usr/local/bin/python -u -c 'import setuptools, tokenize;__file__='"'"'/tmp/pip-install-728nqkv3/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-5sb4lqs2/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-gbqe3dil/overlay --compile" failed with error code 1 in /tmp/pip-install-728nqkv3/cffi/
ERROR: Command "/usr/local/bin/python /usr/local/lib/python3.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-gbqe3dil/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --find-links https://wheels.home-assistant.io/alpine-3.9/armv7/ -- 'setuptools>=40.6.0' wheel 'cffi>=1.8,!=1.11.3; python_implementation != '"'"'PyPy'"'"''" failed with error code 1 in None
[23:01:18] ERROR: An error occurred while installing Home Assistant:
Looking in links: https://wheels.home-assistant.io/alpine-3.9/armv7/
Collecting homeassistant
  Downloading https://files.pythonhosted.org/packages/15/85/89cc12c8d9d6969bdc394e56aae8107cfc7112255b346ffa7fb6f575ce64/homeassistant-0.96.0-py3-none-any.whl (5.0MB)
Collecting python-slugify==3.0.2 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/c1/19/c3cf1dc65e89aa999f85a4a3a4924ccac765a6964b405d487b7b7c8bb39f/python-slugify-3.0.2.tar.gz
Collecting aiohttp==3.5.4 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/0f/58/c8b83f999da3b13e66249ea32f325be923791c0c10aee6cf16002a3effc1/aiohttp-3.5.4.tar.gz (1.1MB)
  Installing build dependencies: started
  Installing build dependencies: finished with status 'done'
  Getting requirements to build wheel: started
  Getting requirements to build wheel: finished with status 'done'
    Preparing wheel metadata: started
    Preparing wheel metadata: finished with status 'done'
Collecting attrs==19.1.0 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/23/96/d828354fa2dbdf216eaa7b7de0db692f12c234f7ef888cc14980ef40d1d2/attrs-19.1.0-py2.py3-none-any.whl
Collecting astral==1.10.1 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/ff/5d/261f49822b7f77c265197d46cdbaaaaf06f458734e9ac55a140dd75bdf29/astral-1.10.1-py2.py3-none-any.whl
Requirement already satisfied: pip>=8.0.3 in /usr/local/lib/python3.7/site-packages (from homeassistant) (19.1.1)
Collecting pytz>=2019.01 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/3d/73/fe30c2daaaa0713420d0382b16fbb761409f532c56bdcc514bf7b6262bb6/pytz-2019.1-py2.py3-none-any.whl (510kB)
Collecting pyyaml==5.1.1 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/a3/65/837fefac7475963d1eccf4aa684c23b95aa6c1d033a2c5965ccb11e22623/PyYAML-5.1.1.tar.gz (274kB)
Collecting cryptography==2.7 (from homeassistant)
  Downloading https://files.pythonhosted.org/packages/c2/95/f43d02315f4ec074219c6e3124a87eba1d2d12196c2767fadfdc07a83884/cryptography-2.7.tar.gz (495kB)
  Installing build dependencies: finished with status 'error'
I haven’t updated yet as I suspect I am going to need to re-check all my climate stuff but I can’t think of ANY reason I would always want the sidebar visible even if it was more compact. It mostly contains functions the admin is considered with not a typical user.
And on mobile I have completely removed both menus with the compact header mode as most of the time they are BOTH not necessary since they are mostly edit functions.
Can be done with CCH.
Sounds like I should wait a few days for the custom lovelace components to update and I should be good to go.
Just hope the compact header can still allow the notification icon to be visible and not part of the side bar.
Not a big fan of UI items that stick out and can’t be hidden. This is kind of a step back from “clean” UI.
It can not.
Use the solution posed by @aidbish above.
Same here with Hass.io Docker install.
Same here, but history has taught me to always wait for the .1 release, so I’m not clicking upgrade just yet.
I don’t mind the new sidebar arrangement, but
  1. I have only tried on my desktop so far; and
  2. I agree you should be able to get rid of it.
There is a big blog about the climate rewrite. Please read the post above !
The new Dev Tools are awesome.
Going back to them and seeing the same states/templates is realy great!
Thanks for this!
The Hue integration is broken after I updated to .96 - other that have this issue?
I see no errors in the logs, but every Hue light or sensor is unavailable.
