Hi all.
Unfortunately broadlink switch seems broken (was OK in 95):
2019-07-18 11:47:25 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py", line 126, in _async_setup_platform
SLOW_SETUP_MAX_WAIT)
File "/usr/local/lib/python3.7/asyncio/tasks.py", line 416, in wait_for
return fut.result()
File "/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/broadlink/switch.py", line 80, in setup_platform
broadlink_device = broadlink.rm((ip_addr, 80), mac_addr, None)
File "/srv/homeassistant/lib/python3.7/site-packages/broadlink/__init__.py", line 529, in __init__
device.__init__(self, host, mac, devtype)
File "/srv/homeassistant/lib/python3.7/site-packages/broadlink/__init__.py", line 171, in __init__
self.update_aes(key)
File "/srv/homeassistant/lib/python3.7/site-packages/broadlink/__init__.py", line 184, in update_aes_crypto
backend=default_backend())
File "/srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/backends/__init__.py", line 15, in default_backend
from cryptography.hazmat.backends.openssl.backend import backend
I don’t see why there has to be a tradeoff. You want icons? Then you gotta lose the ability to hide the menu!
Eh?
I’m not fond of the workaround which is install and configure a completely different menu.
Car Customer: I don’t like this new triangular steering wheel. I prefer the round one.
Car Dealer: It’s the latest thing. It’s better. Trust me.
Car Customer: Can I get a round one?
Car Dealer: Sure. Just replace it yourself.
Having similar issues on my xiaomi vacuum cleaner here too, with the same ImportError about OPENSSL_1_1_1.
xiaomi_miio: Error on device update!
ImportError: /usr/lib/arm-linux-gnueabihf/libssl.so.1.1: version `OPENSSL_1_1_1' not found (required by /srv/homeassistant/lib/python3.7/site-packages/cryptography/hazmat/bindings/_openssl.abi3.so)
I’ve lost the ability to use ‘boost’ for my Hive I can set the device to on (on), off (off), and eco (which seems to map to ‘schedule’ on the Hive) - any ideas @rendili?
My hassio log spits out something along the lines:
19-07-18 11:49:41 INFO (SyncWorker_9) [hassio.docker.interface] Update image homeassistant/qemux86-64-homeassistant:0.95.4 to homeassistant/qemux86-64-homeassistant:0.96.0
19-07-18 11:49:41 INFO (SyncWorker_9) [hassio.docker.interface] Pull image homeassistant/qemux86-64-homeassistant tag 0.96.0.
19-07-18 11:50:33 ERROR (SyncWorker_9) [hassio.docker.interface] Can't install homeassistant/qemux86-64-homeassistant:0.96.0 -> 404 Client Error: Not Found ("no such image: homeassistant/qemux86-64-homeassistant:0.96.0: No such image: homeassistant/qemux86-64-homeassistant:0.96.0").
19-07-18 11:50:33 WARNING (MainThread) [hassio.homeassistant] Update Home Assistant image fails
Reading the “404 - not found” error I thought the image might be taken down, so I tried pulling the image locally (docker pull homeassistant/qemux86-64-homeassistant:0.96.0) but this works just fine.
Unfortunately we had to move the hotwater device from climate to water_heater, and at the moment water_heater does not support any boost functionality and does not have a an auto mode, so for now in the short term we have had to map this to eco.
