Is it just me, or is the 0.98.4 particular unstable.
I’ve now twice experienced weird crash after updating lovelace.
I added two custom-graph cards in a vertical stack, to an existing horizontal stack, and boom, nothing responded, then after a while it came back, and then the hassio tab didn’t work.
I saw this yesterday as well a few times.
@bbrendon I have the same issue with IOS 1.5 app…although not sure if this is due to lovelace but after upgrading I can’t browse anymore my frontend.
It loads but it is irresponsive
No, I haven’t, I’ll have to experiment with that in the weekend, so far it’s only when configuring cards it gets upset here, but it’s a running system, so it won’t be popular for me to tear out the installed cards
Yeah but it is running great ever since… like… for 12 hours. lol I’ve done it today. I will see if everything goes well… like for a few days (like I was able to do prior updating to 0.98.4) then I’ll post an issue
But yeah, you a definitely right! Would not let HACS down.
Hey JayF - I think I have the same issue - for me the instabillity problems started with HACS 0.13.3, I then rolled back to 0.13.0 - were everything was working fine… After some time I decided to give it another try with 0.15.7 now - and the instabillitiy issues are back. Have you created an issue on github? Or did you find a cause for this issues?
No I haven’t created an issue on github… and I haven’t installed HACS back neither. Not that I’m not interested into HACS anymore… but I haven’t got enough time to test it again. But yeah, eversince HACS is completely uninstalled, I haven’t experienced any issues.
That being said, I’m running Home Assistant off a 5 years old Intel NUC. This computer is not fast compared to NUCs these days. Maybe running HA on a much decent computer would have made the whole thing a lot much better…
I’m running it on a Pi 3B+ with docker - memory consumption is about 55%… My github issue got closed because there is nothing suspicious in the logs. I already enabled debug logging for hacs and homeassistant.core - but it just restarts without any notice. Strange thing is that it runs stable for weeks without HACS, so I don’t suspect that it is an hardware performance issue…
Yeah same here… I haven’t touched HA for a while eversince HACS has been uninstalled. That being said, I’m about to buy a faster Intel NUC and from there I will reinstall HACS to definitely rule out the hardware performance as the cause of the issue.
