0.98 Bug : Configuration -> Server Control -> Server Management -> Restart?
0.98 Bug : Configuration -> Server Control -> Server Management -> Restart ?
It does not seem to work anymore. I have to go to hassio -> System -> Reboot to refresh my changes in configuration.
Run a configuration check - it won’t restart if there’s any errors.
I always do. Had bad experience before, hassio not coming up again without check.
So are there errors in the log after you run a config check?
A better option is to run the config check from the CLI.
This is what I see in the log :
19-09-02 06:23:20 INFO (SyncWorker_12) [hassio.docker.interface] Restart homeassistant/qemux86-64-homeassistant
19-09-02 06:23:29 ERROR (MainThread) [hassio.utils] Can’t execute restart while a task is in progress
Found out : clicking a second time on restart works
Did not have this behavoir before.
