0.99: Withings, Device Automations, launch Home Assistant Cast from Python
@tom_l, @aidbish
It’s funny how you can overlook things staring you in the face. I must have seen this ‘Unused entities’ option a million times but reading this made me think, “hhmmm, this could be useful”!
But I get an empty list.
I suppose the first question is; does this work in YAML mode?
are you using a custom theme, if so try using default one,
I was, but changing to Default theme didn’t help…
do a refresh of browser
Sorry, still nothing…
can confirm it works in yaml mode:
but apparently it doesn’t understand includes yet… all my entities are there. I use only !includes in my ui-lovelace.yaml…
Now that I’ve found the “unused devices” view, it all make way more sense, thanks!
Thanks for checking and…
I use packages which are all includes so I guess that must be the reason…
yours seems to have slightly different wording
Maybe a cache issue? If you try with another browser?
mmm, what I meant to say is I see all of my entities in the unused entities.
You seem to see none?
Ahh, yes, I see none.
And @aidbish that wording looks a bit more than slightly different!!
What on earth could be going on here?
well, at least we have the same interface :wink:
29
Hmmm…
Snap!
Weird…
Where do you find this view?
Or is it the same as /config/devices/dashboard?
I just can´t find a “Unused entities” just like your picture.
Nver mind, I found it in the Lovelace UI config.
Is anyone else seeing 1000’s of messages in the HA log related to withings?
I see these three
Sleep data has no series, setting state to None
No measure groups found, setting state to None
No sleep data, setting state to None
I have 25,000 - 50,0000 for each of these in the last 24 hours.
My only withings device is a sleep pad.
hmm, that link sure doesnt look right for logging a ticket
https://www.nabucasa.com/support/
Except the page you point to does refer to Freshdesk
Help Desk Software by Freshdesk
