0.99: Withings, Device Automations, launch Home Assistant Cast from Python
Seeing this error with 0.99 that I have not seen before:
https://10.1.1.100:8123/frontend_latest/chunk.43dcfc6e5b8d18714299.js:1007:141 TypeError: e.model is undefined
Also HA has discovered a certificate expiry integration though I am unable to configure it. Clicking on ‘Configure’ does nothing.
I do have this existing sensor config:
- platform: cert_expiry
  host: my_domain_redacted.duckdns.org
Though this sensor is now unavailable in my Lovelace front end.
I could not find any sensor in the dev tools states page similar to my previous sensor.
Is it possible to have two pihole instances?
According to this Github issue, it looks like the re-factoring of the component has broken the ability to have multiple instances running.
Tom - it’s now an integration. Try removing from config, restarting then adding integration, restarting and adjusting the lovelace card.
I will but the docs do say it should be possible manually:
has the name of it changed? check states?
This update killed my trådfri connection. Can’t even reconnect it under integrations. I’m 100% sure that the code is correct. Screenshot_20190919_074337|230x500
Nope. Was working before the update.
After removing the config and restarting the discovery has gone away. Grrr…
manually add it + bottom right. Certificate.
can we update to this by clicking update in the system manager tool:?
I did. All good.
Same here with Tradfri configured in configuration.yaml
possibly fixed by this
https://github.com/home-assistant/home-assistant/issues/26673
No logs = no issue
Is it possible under 0.98> to customize the device trackers anymore for the UniFi integration? I had pictures customized for the families phones but I can’t see where to do this under the 0.99 integration as the devices are no longer in known_devices.yaml. Am I missing something?
On a 2nd note, is there an easy way to remove all of my IoT devices that are appearing in the UniFi integrations page now (albeit unavailable)?
@cben0ist some of us couldn’t get Withing to woork in the beta version of 0.99
I have updated the issue ticket, even though it was closed down.
https://github.com/home-assistant/home-assistant/issues/26613
Is the new !secret option for hassio add-ons new since .99 or what’s it there before?
Also is it compatible for every add-on? Or needs to be compatible with .99 ?
Thnx
@xbmcnut I posted on this after @finity made the same comment as you have. Post #18.
It is in the release notes at the top of the page, so it is obviously new in 0.99.
its not actually in the release notes, is just in the blog page … the blog page sometimes mentions things that were already available, just for news
Thanks. So do we add the devices manually now?
