Same here, also under the device list, is there any way to remove the devices from that list? Would be nice if there could be a shortcut to disable, hide, customize, when you click on them
It shows Z-Wave devices that I thought i removed from HA, like none of their entities are present in the Entities Registry yet they show up in the Device list.
Love this view, hopefully the new Unused Device view can be integrated into other parts of HA like the Entities Registry, or even Customization (so you can bulk disable things, and see which ones have been working etc)
There are docs missing for (at least deCONZ) device automations in YAML.
I was able to ‘track’ them by adding automation in UI and looking at the file, but couldn’t find the description anywhere near automations nor deCONZ on website.
Also experiencing this issue with the Withings integration. FWIW more detail will appear in your browser console:
ha-config-entries-dashboard.ts:170 Uncaught TypeError: Cannot read property ‘item’ of undefined at HTMLElement._continueFlow (ha-config-entries-dashboard.ts:170) at _.handleEvent (parts.js:434) at HTMLElement.__boundHandleEvent (parts.js:400)
Can anyone teach me how to use cast.show_lovelace_view in detail?
I can cast to google hub like this:
- service: cast.show_lovelace_view
entity_id: media_player.kitchen
view_path: default_view
But It shows what I do not want. Not in correct place and display language is transtated into Hub’s language.
ah , not the case here, i dont have lists in my secrets file
can you show me how you used the secrets in the add-on config, can you copy an example from there? the whole config section
