Just moved from Vera to HA I got rid of all my Fibaro sensors out of Vera coz they were causing problems on my zwave network…moved to Aeotec Tri sensors which worked perfectly on my old Vera
I have Aeotec Z Stick 7 with the latest firmware but I cant get the battery level to show, I adapted the config below and set it as an automation but still nothing
I have the same issue with the Aeotec Tri Sensor not reporting battery. A few were very helpful with suggestions on polling the battery separately, but that did not pull the data required. I have a wakeup interval of 30 minutes while troubleshooting this.
