1, 2, 3 and 4 channel namron zigbee switch
A blueprint for 1, 2 3 and 4 channel namron zigbee switch. This one uses zigbee2mqtt and supports controlling brightness by long pressing.
blueprint:
  name: Z2M - Namron 4 channel
  description: Controls switch on namron
  domain: automation
  input:
    switch:
      description: Namron switch to use
      selector:
        entity:
          domain: sensor
    button_1_on:
      name: Button 1 - on click
      description: Action to run on click of button 1
      default: []
      selector:
        action: {}
    button_1_off:
      name: Button 1 - off click
      description: Action to run off click of button 1
      default: []
      selector:
        action: {}
    button_1_brightness_up:
      name: Button 1 - brightness up
      description: Action to increase brightness of button 1
      default: []
      selector:
        action: {}
    button_1_brightness_down:
      name: Button 1 - brightness down
      description: Action to decrease brightness of button 1
      default: []
      selector:
        action: {}
    button_2_on:
      name: Button 2 - on click
      description: Action to run on click of button 2
      default: []
      selector:
        action: {}
    button_2_off:
      name: Button 2 - off click
      description: Action to run off click of button 2
      default: []
      selector:
        action: {}
    button_2_brightness_up:
      name: Button 2 - brightness up
      description: Action to increase brightness of button 2
      default: []
      selector:
        action: {}
    button_2_brightness_down:
      name: Button 2 - brightness down
      description: Action to decrease brightness of button 2
      default: []
      selector:
        action: {}
    button_3_on:
      name: Button 3 - on click
      description: Action to run on click of button 3
      default: []
      selector:
        action: {}
    button_3_off:
      name: Button 3 - off click
      description: Action to run off click of button 3
      default: []
      selector:
        action: {}
    button_3_brightness_up:
      name: Button 3 - brightness up
      description: Action to increase brightness of button 3
      default: []
      selector:
        action: {}
    button_3_brightness_down:
      name: Button 3 - brightness down
      description: Action to decrease brightness of button 3
      default: []
      selector:
        action: {}
    button_4_on:
      name: Button 4 - on click
      description: Action to run on click of button 4
      default: []
      selector:
        action: {}
    button_4_off:
      name: Button 4 - off click
      description: Action to run off click of button 4
      default: []
      selector:
        action: {}
    button_4_brightness_up:
      name: Button 4 - brightness up
      description: Action to increase brightness of button 4
      default: []
      selector:
        action: {}
    button_4_brightness_down:
      name: Button 4 - brightness down
      description: Action to decrease brightness of button 4
      default: []
      selector:
        action: {}
mode: restart
max_exceeded: silent
  - platform: state
    entity_id: !input "switch"
condition:
  - condition: and
    conditions:
        {{ trigger.to_state.state not in ["", "None"] }}
  - variables:
      command: "{{ trigger.to_state.state }}"
  - choose:
      - conditions:
          - "{{ command == 'on_l1' }}"
        sequence: !input "button_1_on"
      - conditions:
          - "{{ command == 'off_l1' }}"
        sequence: !input "button_1_off"
      - conditions:
          - "{{ command == 'brightness_move_up_l1' }}"
        sequence:
          - repeat:
              sequence: !input "button_1_brightness_up"
              until:
                - condition: state
                  state: brightness_stop_l1
      - conditions:
          - "{{ command == 'brightness_move_down_l1' }}"
        sequence:
          - repeat:
              sequence: !input "button_1_brightness_down"
              until:
                - condition: state
      - conditions:
          - "{{ command == 'on_l2' }}"
        sequence: !input "button_2_on"
      - conditions:
          - "{{ command == 'off_l2' }}"
        sequence: !input "button_2_off"
      - conditions:
          - "{{ command == 'brightness_move_up_l2' }}"
        sequence:
          - repeat:
              sequence: !input "button_2_brightness_up"
              until:
                - condition: state
                  state: brightness_stop_l2
      - conditions:
          - "{{ command == 'brightness_move_down_l2' }}"
        sequence:
          - repeat:
              sequence: !input "button_2_brightness_down"
              until:
                - condition: state
      - conditions:
          - "{{ command == 'on_l3' }}"
        sequence: !input "button_3_on"
      - conditions:
          - "{{ command == 'off_l3' }}"
        sequence: !input "button_3_off"
      - conditions:
          - "{{ command == 'brightness_move_up_l3' }}"
        sequence:
          - repeat:
              sequence: !input "button_3_brightness_up"
              until:
                - condition: state
                  state: brightness_stop_l3
      - conditions:
          - "{{ command == 'brightness_move_down_l3' }}"
        sequence:
          - repeat:
              sequence: !input "button_3_brightness_down"
              until:
                - condition: state
      - conditions:
          - "{{ command == 'on_l4' }}"
        sequence: !input "button_4_on"
      - conditions:
          - "{{ command == 'off_l4' }}"
        sequence: !input "button_4_off"
      - conditions:
          - "{{ command == 'brightness_move_up_l4' }}"
        sequence:
          - repeat:
              sequence: !input "button_4_brightness_up"
              until:
                - condition: state
                  state: brightness_stop_l4
      - conditions:
          - "{{ command == 'brightness_move_down_l4' }}"
        sequence:
          - repeat:
              sequence: !input "button_4_brightness_down"
              until:
                - condition: state
I’ve tried this blueprint, but my switches only shows up as sensor.myswitch_battery. Both ZHA (which i dont expect to work) and MQTT switches. I have a similar blueprint for my ZHA devices which works fine, except dimming.
But why can I only see the battery part of my switches in the dropdown menu?
This is the switch I’m using:
Hi, I have used this blueprint and i like it.
After HA and Z2m updates im missing the Namron K8 sensor entity, any idea?
Because:
  • You have Z2M version 2.0.0 or higher
  • The action entity was disabled by default in Z2M version 2.0.0
  • The switch only used to expose battery and action, so now only shows battery.
  • You did not enable legacy action legacy_action_sensor
Did you read the Z2M breaking changes before you updated?
I get all 4 switches working for on and off commands.
However i can’t get dimming to work.
What am I doing wrong.?
