1 hass account on 2 different locations + nebucasa
Hello
so i was trying to find some answers on this i am kinda new to this so here it goes.
i wanted to ad another device with homeassistant like rasberry pi to another location and then log in with same account i am curently using is that possible.
what to expect is that the device there can be seen from there and then hass can detect devices while i am in the curent location.
example shelly device lights switch are coneccted there. then add raspberry pi with hass on same account. that iam using here. then when i open hass here will i see them also as new devices discovered.
i do have nebucasa.
You can run 2 instances and use remote_Homeassistant to view one instance from the other.
Or you can have instances, 2 NabuCasa accounts and see them both on your phone (but not at the same time as you need to switch between servers In the Ha app).
[edited for clarity]
thanks for your answer so that is not possible on one account.
do you know how to add a shelly device to HA while i am at another countrey
I don’t have any Shelly devices - sorry.
all good hope sombody else got this to work
https://www.nabucasa.com/faq/
