Hi All,
Just starting my HA journey - and I’m looking to shift my current home made (programmed) home heating to HA.
The setup at present is:
lots of DS18b20’s dotted around connected to 3 RPI’s
the data gets written off to mariadb
some python scripts check if the zone is cold and turn on/off a relay acordingly.
My HA is running on a VM on a repurposed desktop via HASS.IO.
What i am looking for is a way for my pi’s to report the ds18b20 data to Home Assistant, ideally without too many scripts as a go between for the ease of support/replacements.
I was hoping to use the 1-Wire module, but it seems that the ds18b20 needs to be connected to the same hardware that HA is running on.
I would install Mosquitto either on one of the Pi’s or on Home Assistant itself. Then on each of the PI’s install mosquitto-clients you can then publish whatever data you want to Home Assistant on MQTT (Mosquitto), by using the program mosquitto_pub on the Pi’s. Just set up MQTT sensors on Home Assistant to receive the data:
I’ll take a look at setting up MQTT to publish - I already have mosquito setup on HA for tasmota and my alarm, so I guess publishing my sensors may be the cleanest option!
