platform: generic_thermostat
heater: switch.relay3
target_sensor: sensor.tt11
min_temp: 15
max_temp: 23
target_temp: 21
cold_tolerance: 0.3
hot_tolerance: 0
min_cycle_duration:
seconds: 5
keep_alive:
minutes: 3
the problem is that it appears to have no current temperature. I probably have a typo somewhere but I have spent a lot of time trying to get home assistant to control a simple electric heater in my office as a test before I move on to more complex control. But I have not been able to get a trigger or generic thermostat to react to temperature from 1-wire
thank you very much. I have spent a significant amount of time on Home assistant over the last month as I think it can very useful, but I was getting ready to give up on it has I could not get the temperature to work
just a note. I have tried using Home assistant on the new rasbian strech. it caused me a lot of problems. I have gone back to Jessie and everything seems to be more stable
Yep I’m having a few problems atm, my main RPI3 went down and so I’m reduced to using an old RPI1 which is painfully slow and is taking 1 hr or so to start up
A few things seem not to work very well on Hassbian atm but whether that’s my pi being slow or a combination of stretch as well I don’t know yet
