Salam Alikom Brothers,
I have been struggling with the integration for Athan, it is not accurate I wanted to share my solution on how I have captured the data for our official source for the timing in Dubai.
Our official source is IACAD website
I have used the scrape integration that comes preinstalled with Home Assistant
You need to have internet access to the HA instant. Below you can find the code for the senor,
- platform: scrape
resource: https://services.iacad.gov.ae/SmartPortal/en/Timings
select: "td"
index: 1
value_template: '{{ value.split("AM")[0] }}'
unit_of_measurement: hours
- platform: scrape
select: "td"
index: 7
value_template: '{{ value.split("PM")[0] }}'
- platform: scrape
select: "td"
index: 10
- platform: scrape
select: "td"
index: 13
- platform: scrape
select: "td"
index: 16
##### the below sensors is used for automation purpose #####
fajr_24:
friendly_name: 'Fajr 24 Format'
icon_template: "mdi:clock"
value_template: >
{% set fajr_time_in_12_fromat = as_timestamp(states.sensor.date.state + ' ' + states.sensor.Fajr_time.state) %}
{{fajr_time_in_12_fromat|timestamp_local}}
dohr_24:
friendly_name: 'Dohr 24 Format'
value_template: >
{%- set dohr_time_in_12_fromat = as_timestamp(states.sensor.date.state + ' ' + states.sensor.dohr_time.state) %}
{{dohr_time_in_12_fromat|timestamp_local}}
asr_24:
friendly_name: 'Asr 24 Format'
value_template: >
{%- set asr_time_in_12_fromat = as_timestamp(states.sensor.date.state + ' ' + states.sensor.asr_time.state) %}
{%- set asr_time_in_24_fromat = asr_time_in_12_fromat | int + 43200 %}
{{asr_time_in_24_fromat|timestamp_local}}
magrib_24:
friendly_name: 'Magrib 24 Format'
value_template: >
{%- set magrib_time_in_12_fromat = as_timestamp(states.sensor.date.state + ' ' + states.sensor.magrib_time.state) %}
{%- set magrib_time_in_24_fromat = magrib_time_in_12_fromat | int + 43200 %}
{{magrib_time_in_24_fromat|timestamp_local}}
isha_24:
friendly_name: 'Isha 24 Format'
value_template: >
{%- set isha_time_in_12_fromat = as_timestamp(states.sensor.date.state + ' ' + states.sensor.isha_time.state) %}
{%- set isha_time_in_24_fromat = isha_time_in_12_fromat | int + 43200 %}
{{isha_time_in_24_fromat|timestamp_local}}
test_24:
value_template: >
{%- set test = "21:56" %}
{%- set test_24 = as_timestamp(states.sensor.date.state + ' ' + test) %}
{{test_24|timestamp_local}}
This will generate sensors only, now you need to do the automations as per your needs, there are samples here in the community:
Adhan automation (أذان التلقائي) using Home Assistant and Google Home Mini
Automate Islamic Adhan (also called Azan or Azzan) or other prayer calls
Azaan/Adhan/Azan on your Alexa devices
To use it as time trigger, choose in the triggers section: Trigger type as template, add ID if you need then the Value template is as below:
{{ as_timestamp(states('sensor.asr_24'))|timestamp_custom('%H:%M', true) == states('sensor.time') }}
This is only for 1 example you need to change the sensor for each automation.
Salam Alikom
