šŸ“ 100% Templatable Lovelace Configurations
Unfortunately somehow is not working and I think 50% of this is my fault :smiley:
             - type: custom:config-template-card
                config:
                  - type: entities
                    title: House Members
                    show_header_toggle: false
                    entities:
                      - entity: person.andrea
                        type: "custom:secondaryinfo-entity-row"
                        secondary_info: "OnePlus 5 Battery: [[ sensor.andrea_oneplus5_battery ]]% - ${this.hass.is_states['binary_sensor.andrea_oneplus5_charging', 'true'] 'Charging' : 'Not Charging'}"
                      - entity: person.xxxxx
                        secondary_info: "Honor 8 Battery: [[ sensor.xxxxx_honor8_battery ]]%"
This is the code I am using, true is that the line in the template check in HA doesn’t seem to return not an error nor the expected result, so, not sure if it’s me or what :slight_smile:
@Maaniac code aswell does the same in the template test to be fair :slight_smile:
I also tried the same with the mini-graph-card using @Maaniac icon config, still got a configuration error:
                        icon: "${this.hass.states['sensor.dark_sky_temperature'].state >= '10' ? 'mdi:thermometer-chevron-up' : 'mdi:thermometer-chevron-down'}"
My guess in this one is the >= but to be honest, that seems to be correct to me
Any hint please? ^^
your first one isn’t defining templates correctly ${}. Also, you’ll need to template the full line, not just parts of it. The full thing is evaluated as Javascript code.
on your 2nd one, you’ll need to convert the string to a number to evaluate most likely
Thanks @iantrich , I will check that :slight_smile:
Side note, the dark_sky sensor return a number as far as I can tell :slight_smile:
Also becaue I believe that various graph cards are using those values as they are to generate the graph (but again, I might be wrong)
You have '10' though, which is a string
There is a typo in the card name.
Hi @arsaboo
Yes I saw that and already fixed, didn’t help tho :smiley:
Thanks :slight_smile:
Oh, okay that makes sense :slight_smile:
I will try without quotes!
Cheers
Thank you for your contribution! If I understand this thing correctly, it’s a card that allows you to template other cards. In effect, it overrides other cards and gives them templating abilities with access to the hass object.
If my interpretation is correct, it makes me wonder why templating isn’t a common ability of all cards. It seems one often finds a need to tweak a card’s appearance, or even conditional visibility, in a way that the card’s author never envisioned. Maybe templating should be part of Lovelace’s DNA, an inheritable trait in order to make it easily available to existing stock, custom, and future cards.
Of course, I offer this opinion with little knowledge of Lovelace’s innards so I might just be asking for the impossible.
So, I tried the following and it does not work for me (Invalid Configuration):
        card:
          type: entities
          title: Stocks
          entities:
            - entity: sensor.dow_futures
              icon: "${parseFloat(this.hass.states['sensor.dow_futures_change_pct'].state) > 0 ? 'mdi:arrow-up-bold-circle' : 'mdi:arrow-down-bold-circle'}"
I tried without parseFloat and it still did not work.
Also, I am guessing we cannot change icon_color.
Ok my attempt without quote didn’t help, still same issue.
icon: "${this.hass.states['sensor.dark_sky_temperature'].state >= 10 ? 'mdi:thermometer-chevron-up' : 'mdi:thermometer-chevron-down'}"
The other one, I tried 3 different way, none of them work an the second one should simply work
#secondary_info: "OnePlus 5 Battery: [[ sensor.andrea_oneplus5_battery ]] - ${this.hass.states['binary_sensor.andrea_oneplus5_charging'].state === "true" ? 'Charging' : 'Not Charging'}"
#secondary_info: "${this.hass.states['binary_sensor.andrea_oneplus5_charging'].state === "true" ? 'Charging' : 'Not Charging'}"
secondary_info: "${this.hass.is_state['binary_sensor.andrea_oneplus5_charging', 'true'] ? 'Charging' : 'Not Charging'}"
I am not sure about what am I doing that wrong to be honest
I tested all those templates in the UI and none of them give error, but all of them just print the same code, not the result for some reason…
I am lost xD
Curious thing, not ure if anyhow related.
On the temperature issue, I got an error in the browser console:
    at HTMLElement.setConfig (config-template-card.js?track=true:2290)
    at create_card_element_createElement (401352253e833b70a294.chunk.js:4823)
    at createCardElement (401352253e833b70a294.chunk.js:4823)
    at HTMLElement._createCardElement (401352253e833b70a294.chunk.js:3618)
    at _cards.config.cards.map.card (401352253e833b70a294.chunk.js:3615)
    at Array.map (<anonymous>)
    at HTMLElement.setConfig (401352253e833b70a294.chunk.js:3615)
On the second one (charging/not charging) I don’t get any error in the console.
Lovelace core will not support templating, that has been stated from the beginning by balloob, but this should cover all use cases, I believe where templating could be beneficial. I think
Add these logs back if you want to see what you’re getting for the evaluated template: https://github.com/custom-cards/config-template-card/commit/bcad27dc9ed96520a5cbbd11a79a4a2da5caaafa#diff-9adab9572c0667f4f32ee92b4e87df0cL40
You can only do what the card supports. entities card does not support icon_color.
As noted in the readme, you need to use the full name of cards, i.e. custom:hui-entities-card
Edit: I COULD drop the custom requirement…but not sure if I should or not. Seems to fit better with what is done by core already :woman_shrugging:, but I’m not going to maintain a list of what cards/rows/elements are in core, so the full name will be required regardless
That wasn’t the case until 20 seconds back :wink:
In any case, the following doesn’t work either:
        card:
          - type: custom:hui-entities-card
            title: Stocks
            entities:
                icon: "${this.hass.states['sensor.dow_futures_change_pct'].state > 0 ? 'mdi:arrow-up-bold-circle' : 'mdi:arrow-down-bold-circle'}"
It was in the readme, below the example, just not the example itself. And since apparently asking for people to update Readme is rude, I did it myself just now…
@arsaboo Haven’t you missed off a config?
In any case this doesn’t work either.
    config:
      title: TESTING
      entities:
        - entity: switch.hall_light
          icon: "${this.hass.states['switch.hall_light'].state === 'on' ? 'mdi:music' : 'mdi:sleep'}"
Add some logs, might be a bug in the traversing of the nested objects
Edit: Yeah there probably is, I think i ONLY did objects and not lists :man_facepalming: maybe someone can check it out.
@Mariusthvdb, didn’t you want this
