May be I am wrong, but:
Should it be:
image: '${st
Also, instead of this:
try this (it works for me):
states[''media_player.samsung_tv'']
Should it be:
image: '${st
using this now:
this.hass.states['media_player.samsung_tv'].attributes['media_title']
works fine. Thanks
HI all
Can someone help me to check this sensor i have been cracking my head for two days and i still dont see the error, in the developer tools template all shows as its supposed but i cant make it work in the sensor it self.
"{{ state_attr('sensor.plex_recently_added', 'data')[1]['aired'] }}"
**"1987-11-20"**
"{{ state_attr('sensor.plex_recently_added', 'data')[1]['title'] }}"
**"Date With an Angel"**
"{{ state_attr('sensor.plex_recently_added', 'data')[1]['poster'] }}"
**"/local/upcoming-media-card-images/plex/Plex_Recently_Added/p173500.jpg"**
{{ state_attr('sensor.plex_recently_added', 'data')[1]['aired'].split("-")[0] }}
**1987**
"{ "library_name": "Movies", "title": "{{ state_attr('sensor.plex_recently_added', 'data')[1]['title'] }}", "Year": "{{ state_attr('sensor.plex_recently_added', 'data')[1]['aired'].split("-")[0] }}" }"
**"{ "library_name": "Movies", "title": "Date With an Angel", "Year": "1987" }"**
My sensor
sensors:
plex_movie_to_play:
friendly_name: "play movie"
icon_template: mdi:movie-roll
value_template: "{{ "library_name": "Movies", "title": "{{ state_attr('sensor.plex_recently_added', 'data')[1]['title'] }}", "Year": "{{ state_attr('sensor.plex_recently_added', 'data')[1]['aired'].split("-")[0] }}" }"}}
i get:
bad indentation of a mapping entry at line 150, column 53:
… te: "{{ “library_name”: “Movies”, “title”: "{{ state_attr('senso …
this is for the plex service:
this one works like this and the idea is to have the media_content_id from a template
tap_action:
entity_id: media_player.plex_tv_livingroom
media_content_type: movie
media_content_id: ‘{ “library_name”: “Movies”, “title”: “Date With an Angel” }’
thanks for your help!!
Just checked the latest update of the card.
I think it is a good step forward to provide a possibility to use this card for a single entity row.
But I cannot use styles (card-mod) in this case.
Please check this: 🔹 Card-mod - Add css styles to any lovelace card
Hello all, there must be something I don’t understand. I tried to use this plugin in order to change the icon based on the state of my sensor here is the code I entered in the UI
type: 'custom:config-template-card'
variables:
ENTREE_STATE: 'states[''binary_sensor.window_door_sensor_entree''].state'
JARDIN_STATE: 'states[''binary_sensor.openclose_portejardin''].state'
entities:
- entity: binary_sensor.window_door_sensor_entree
- entity: binary_sensor.openclose_portejardin
- entity: binary_sensor.openclose_11
card:
type: entities
entities:
icon: '${ENTREE_STATE === ''off'' ? ''mdi:door'' : ''mdi:door-open'' }'
icon: '${JARDIN_STATE === ''off'' ? ''mdi:door'' : ''mdi:door-open'' }'
title: Ouvertures_test
state_color: true
my issue is that when I open the door, nothing happened (the “standard” card is working fine and shows the icon in other color)
Nicolas
Is there a way to manipulate (e.g. the icon, the text) only one row in a normal entity card? Saw the row option and example
type: entities
entities:
- type: 'custom:config-template-card'
variables:
- states['light.bed_light'].state
entities:
- light.bed_light
row:
type: section
label: "${vars[0] === 'on' ? 'Light On' : 'Light Off'}"
- entity: light.bed_light
But currently I’m not able to insert a customized entity row, but only a section as in this example.
Though with this example and row, it is possible to place/add someting like
- entity: "${LIGHT_STATE === 'on' ? 'light.bed_light' : 'climate.ecobee'}"
icon: "${GARAGE_STATE === 'open' ? 'mdi:hotel' : '' }"
in the standard entity card.
Wonder why this is not standard behavior of lovelace config. Templating should just be possible everywhere…
Hi!
I love the card, thank you!
I have been using it to display graphs. By using an input_number controlled via a slider, I could select the number of days to display on the graph.
I want to move to the next step, use a input_select to select the entity I want to display on the graph. Any clue how I can do so that the user select a friendly name and the card understands an entity_id?
I was wondering if this card can help me to display an entity state containing json-formatted text, in tabular format in LL, perhaps in combination with existing cards like Ian’s List Card or the Flex Table Card, but I don’t understand all this well enough to make it work.
Any pointers or thoughts you may have on how to (best) do this will be highly appreciated.
Background:
I have a couple of ESP32’s out there that can be configured through MQTT to function in a certain way, and they can report this configuration back as a json-formatted MQTT message. I would like to show this configuration in a LL card as text, simiilar to how HA shows additional information when the Entity WiFi status is displayed (indicated by the arrow in the screen capture below).
So basically I’d like to display the name/value pairs as text, in tabular format, optionally with some basic formatting to display the names in bold etc.
I understand that I can create entities for each name/value pair, use templates to extract the values, and display them in the traditional way. But I prefer to not go this route, with the associated overhead of setting up these entities for each device and maintaining them should the sketch change.
Below is an example of the json data to display in tabular format:
"CAM_enabled":true,
"PIR_enabled":true,
"PIR_delay":20,
"ReportState":true,
"ReportWiFi":false,
"TempInterval":600,
"StateInterval":600
Below: How HA displays the additional information below the WiFi entity status.
I think you can as they will all be attributes. I did a card using this template to show MQTT status info my esp as well. I would have liked to use list or flex table card but neither of those show the icon. You can see the MQTT card I cobbled together in this thread. Anyway I think you can do it not with json but by using the state-attr
Hey all,
not sure where im going wrong, if someone can help?
im trying to have the content update, based on the drop down value, as per this example below.
The reason is that I want to have a “friendly name” in the drop down, however that calls an entity to be used in the card.
type: vertical-stack
cards:
- type: entities
entities:
- entity: input_select.room_temp_display2
show_header_toggle: false
variables:
- 'states[''input_select.room_temp_display2''].state'
entities:
- input_select.room_temp_display2
card:
type: markdown
content: '"${vars[0] }"'
variables:
entities:
card:
type: markdown
content: '"${ if (vars[0] === ''Jamie Office'') return ''abc'' else ''123'';}"'
Alright, so I’m trying to use this custom template to take an input_number from HA and use it as the Target VALUE to control the color_thresholds on a mini-graph. Here’s what I’m using but i’m not getting anywhere.
variables:
- states['input_number.temp_target'].state
entities:
- '${vars[0]}'
cards:
type: horizontal-stack
cards:
type: 'custom:mini-graph-card'
entity:
- sensor.tent_temperature
name_adaptive_color: 'true'
icon_adaptive_color: true
hours_to_show: 24
points_per_hour: 60
show:
labels: false
color_thresholds:
- value: '${vars[0]} - 20'
color: '#82EEFD'
- value: '${vars[0]} - 15'
color: '#63C5DA'
- value: '${vars[0]} - 10'
color: '#1164b4'
- value: '${vars[0]} - 5'
color: '#005FFF'
- value: '${vars[0]}'
color: '#00FF00'
- value: '${vars[0]} + 5'
color: '#FFB111'
- value: '${vars[0]} + 10'
color: '#FF5E00'
- value: '${vars[0]} + 15'
color: '#FF0000'
color_thresholds_transition: smooth
font_size: 50
line_width: 4```
Alternatively I tried this as well.
type: ‘custom:config-template-card’
variables:
Target_Temp: states[‘input_number.temp_target’].state
Current_Temp: states[‘sensor.tent_temperature’].state
entities:
In your code there are errors like:
"color_thresholds"
cannot be inside "show"
group."cards"
but "card"
inside "config-template-card"
."type: 'custom:mini-graph-card'"
but "- type: 'custom:mini-graph-card'"
."entity"
but "entities"
.Please check this code and then make necessary corrections:
variables:
- 'states[''input_number.test_number'']'
entities:
- '${vars[0].entity_id}'
card:
cards:
- type: entities
entities:
- input_number.test_number
entities:
- entity: sensor.cleargrass_1_co2
hours_to_show: 6
points_per_hour: 60
show:
labels: false
fill: true
name_adaptive_color: true
color_thresholds_transition: hard
font_size: 50
line_width: 4
height: 500
color_thresholds:
- value: '${parseFloat(vars[0].state) - 100}'
color: red
- value: '${parseFloat(vars[0].state) - 75}'
color: green
- value: '${parseFloat(vars[0].state) - 50}'
color: magenta
- value: '${parseFloat(vars[0].state) - 10}'
color: cyan
- value: '${parseFloat(vars[0].state)}'
color: orange
- value: '${parseFloat(vars[0].state) + 10}'
color: violet
- value: '${parseFloat(vars[0].state) + 75}'
color: blue
- value: '${parseFloat(vars[0].state) + 100}'
color: brown
Hi All,
WONDERFULL CARD!!!
This working:
variables:
CRYPTO: 'states[''input_select.crypto_test''].state'
entities:
- input_select.crypto_test
card:
type: 'custom:apexcharts-card'
config_templates: bandwidth_chart
header:
title: '${NAME}'
series:
- entity: '${CRYPTO}'
attribute: buy
attribute: sell
output of CRYPTO will be, depends on what I selected in the input_selct.crypto_test:
sensor.eur_1inch
sensor.eur_ada
sensor.eur_bnb
sensor.eur_doge
The card below will pick up those names so I can use them as entities. Select the right attribute and done.
Only thing what I can’t let work is get the friendly_name of the sensors into a variabel so I can add them in the title: part.
Can someone assist me with this?
The output of NAME:
Crypto Test
But this is the friendly_name of the input_select.
Try this:
Tried that, but get the friendly_name of the input_select. And not from the value “the sensor”
is not working. thought use the variable to get the attribute.
Also , what I can see:
This is a state.
Then you are trying to use it as an “entity_id” - which is wrong.
Should be this:
variables:
CRYPTO: 'states[''input_select.crypto_test'']'
entities:
- '${CRYPTO.entity_id}'
card:
header:
title: '${CRYPTO.attributes[''friendly_name'']}'
series:
- entity: '${CRYPTO.entity_id}'
attribute: buy
attribute: sell
Surely it will not.
This isn’t working also.
Still get the friendly_name of the input_select.
the part:
attribute: buy
attribute: sell
keeps loading. So doen’t work.
Ill try to find out to make it work.
This is working for a part. the title part is still not correct. As you can see I get the entity_id as title.
variables:
CRYPTO: 'states[''input_select.crypto_one'']'
STATE: 'states[''input_select.crypto_one''].state'
entities:
- '${CRYPTO}'
card:
header:
title: '${STATE}'
series:
- entity: '${STATE}'
attribute: buy
attribute: sell
I do not understand, what do you mean?
The graph is not showing? The text “loadind” is displayed?
Then check without config-template-card first.
This is NOT CORRECT.
You are using “object” instead of “id”.
“states” = object, not an id.
