📝 100% Templatable Lovelace Configurations
Sorry for my bad English but let me explain:
First tryout
type: 'custom:config-template-card'
variables:
  CRYPTO: 'states[''input_select.crypto_one'']'
entities:
  - '${CRYPTO.entity_id}'
card:
  type: 'custom:apexcharts-card'
  config_templates: bandwidth_chart
  header:
    title: '${CRYPTO.attributes[''friendly_name'']}'
  series:
    - entity: '${CRYPTO.entity_id}'
      attribute: buy
      attribute: sell
Schermafbeelding 2021-02-28 om 15.29.37
This show in title part the friendly_name of the input_select entity.
The 2 graphs not showing
Second tryout
variables:
  STATE: 'states[''input_select.crypto_one''].state'
entities:
  - '${CRYPTO}'
card:
  header:
    title: '${STATE}'
  series:
    - entity: '${STATE}'
      attribute: buy
      attribute: sell
This load the graphs correct. But title part show the value of of the input_select (value is entity_id that is used fo the graphs.
Schermafbeelding 2021-02-28 om 14.26.39
OK, I will try to simulate your case on my setup, may be will help you a bit later.
thank you… in meanwhile I go try as well…
Yes, that was my fault, sorry.
I managed to simulate your case.
The input_select:
input_select:
  test_sensors_for_graph:
    name: "Test: sensors for graph"
    options:
      - sensor.cleargrass_1_co2
      - sensor.cleargrass_1_tvoc
The card:
type: vertical-stack
cards:
  - type: entities
    entities:
      - entity: input_select.test_sensors_for_graph
  - type: 'custom:config-template-card'
    variables:
      CRYPTO: 'states[''input_select.test_sensors_for_graph'']'
    entities:
      - '${CRYPTO.state}'
    card:
      cards:
        - type: entities
          entities:
            - entity: '${CRYPTO.state}'
        - type: history-graph
          entities:
          hours_to_show: 6
          refresh_interval: 0
And with apexcharts-card:
cards:
  - type: entities
    entities:
    variables:
    entities:
      - '${CRYPTO.state}'
    card:
      cards:
        - type: entities
          entities:
        - type: 'custom:apexcharts-card'
          header:
            show: true
            title: '${states[CRYPTO.state].attributes[''friendly_name'']}'
          series:
variables:
entities:
  - '${CRYPTO.state}'
card:
  header:
  series:
      attribute: buy
      attribute: sell
This is how it look like now. @Ildar_Gabdullin You’re my hero!!!
[/quote]
output:
BNB
One little cosmetic thing. How to change this to:
Crypto: BNB
without change the friendly_names of all cryto’s
So just add the “text” Crypto in front of the ${states… part
Try this:
title: '${"HELLO_WORLD: " + states[CRYPTO.state].attributes[''friendly_name'']}'
variables:
entities:
  - '${CRYPTO.state}'
card:
  header:
    title: '${"Crypto: " + states[''input_select.crypto_one''].state}'
  series:
    - entity: '${"sensor.eur_" + states[''input_select.crypto_one''].state}'
      attribute: buy
      attribute: sell
Updated the code.
input_select now have
- ada
- bnb
- dot
etc
etc
This give me more options to get a nice title and combine them as entities with adding some text in front so it will become a sensor:
sensor.eur_ada
sensor.eur_bnb
etc
etc
:smiley:
But you missed this:
entities:
  - '${CRYPTO.state}'
Without it the config-template-card will not be auto updated with new sensor’s data.
It is added… will update the code in post
Hi, can anyone help me with this template?
thanks
- type: custom:config-template-card
  variables: >
      if (window.location.pathname.split('lovelace-mobile/')[1] == 'home')
        return "header_notification";
      else
        return "header_bottom";
  entities:
    - input_boolean.dummy1
  card:
    type: custom:decluttering-card
    template: ${vars[0]}
wrong syntax, where did you take this example?
nowhere, I was trying.
How can I solve it, can you give me an example.
Have a look at this:
variables:
  SUN: 'states[''sun.sun'']'
entities:
  - '${SUN.entity_id}'
card:
  type: entities
  entities:
    - entity: '${SUN.entity_id}'
    - entity: sun.sun
This small example uses templates for:
  • choosing an entity to display;
  • displaying a state of the entity.
Now you can try to correct your code using this example.
Thanks, but my problem is to recall a decluttering-card template based on the path
Try using TWO symbols "'"
split(''lovelace-mobile/'')
if this is still the yaml you are working with, it seems you didn’t declare / name the variable, hence you cant call it in the config?
from the docs:
variables:
  LIGHT_STATE: states['light.bed_light'].state
  GARAGE_STATE: states['cover.garage_door'].state
and in Ildar’s example:
variables:
btw prevent the quoting issues by using the multiline yaml notation:
variables:
  SUN: >
   states['sun.sun']
how can I use the variable as an integer instead of a string? In the picture marked in red, max needs an integer.
Also when I do an arithmetic operation on a variable, how can I reduce the decimal points after the dot? For example, in the following picture, I want 9428K only.
To convert string to int, use parseFloat(string value).
great! thanks. this leads me to the second answer as well.
parseFloat(string value).toFixed(0)
