AleXSR700
(Alex)
November 6, 2022, 10:49am
662
I never took notice of the decluttering card. But would that also work if the parent has to be remove also?
And does it always replace or can it append.
Imagine the decluttering card does not supply a color_threshold. Then the config would be
my_graph_card:
default:
- COLOR_THRESHOLDS: []
card:
color_thresholds: ''
That would break the card if an empty string or null
were not permitted (which is often the case for options).
So you would need to add the parent key plus the child_keys using declutterin card.
e.g.
- entity_id: test
option1: bla
option2: bla
'[[decluttering card]]`
Otherwise it is the same as card-mod, which supplies the value to an existing key and does not supply the key itself (at least not the top level key).
AleXSR700
(Alex)
November 11, 2022, 6:39am
663
Maybe a more simple task
I noticed, that when I have an entities card with input_datetime and input_select they are shown differently in Panel mode.
Is there a way to make them all be the same width (preferrably not full width but without downsizing them in e.g. Masonry mode) and also center them?
AleXSR700
(Alex)
November 11, 2022, 10:45pm
664
Is there a way to use templating in the entities selection already?
I am facing the problem that two entities (input_datetime) keep making my card reload because the value changes every minute. The card itself should be ignoring this change as it is part of an if statement that is not ‘true’.
So I think the problem is, that the config-template-card is monitoring the input_datetime and causes a reload of the card with the new state.
I would like to prevent this, if the input_booleans are both true.
type: custom:config-template-card
entities:
- input_select.dropdown_wildcards
- input_select.dropdown_entities
- input_select.dropdown_areas
- input_select.dropdown_types
- input_boolean.end_datetime_now
- input_boolean.start_datetime_24h
- input_datetime.start_datetime # only if input_boolean.start_datetime_24h returns 'true'
- input_datetime.end_datetime # only if input_boolean.end_datetime_now returns 'true'
If that were possible somehow, it would prevent the regular reloading.
ygeffens
(Yves Geffens)
December 2, 2022, 6:13pm
665
I’m having an issue where my card stopped showing at all. No errors. Just black, not taking up any space.
cards:
- type: custom:config-template-card
variables:
- '''input_number.piek_afname_'''
- if ((new Date()).getMonth()+1 < 10) { "0" }
- String((new Date()).getMonth()+1)
- states[vars[0] + vars[1] + vars[2]]
entities:
- ${vars[3].entity_id}
- sensor.fluvius_verbruik_energy_kwartier_piek
card:
type: entities
entities:
- entity: ${vars[3].entity_id} # replace with input_number.piek_afname_12
name: Hoogste piek deze maand
type: custom:multiple-entity-row
format: precision2
unit: kWh
icon: mdi:transmission-tower
entities:
- entity: sensor.fluvius_verbruik_energy_kwartier_piek
format: precision2
unit: kWh
When I replace the actual entity by (what the result should be) input_number.piek_afname_12, and the card is showing.
So something is going wrong when creating the entity from the variables.
This has been working for half a year or so, and (when I remember correct) stopped working about 2 months ago.
What can be wrong ?
Probably because you have an undefined var.
Change it to (untested):
- if (Number(vars[1]) <= 10) { "0" } else {""}
- states[vars[0] + vars[2] + vars[1]]
ygeffens
(Yves Geffens)
December 2, 2022, 9:23pm
667
It’s working now.
That also explains why it “stopped working about 2 months ago”. month 10 doesn’t need the “0” at the beginning.
Thank you so much !
Edit: I think I have to replace ‘<=’ with ‘<’ otherwise we get month ‘010’ in october.
Note that you may use “vars[x]” to define a “var[y]” - it saves some amount of a code.
This trick is also possible when using “named vars”.
ygeffens
(Yves Geffens)
December 2, 2022, 9:44pm
669
This is indeed pretty cool.
This means that, the moment you define a var, it can be used in the next var.
ygeffens:
in the next var.
and may be before, have not tested yet…
tekker
(fff)
December 20, 2022, 8:47am
671
have you solved this problem yet?
i feel like we need url param support
I see no problems with generating urls:
type: vertical-stack
cards:
- type: entities
entities:
- entity: input_text.test_text
entities:
- input_text.test_text
variables:
URL: '"https://" + states["input_text.test_text"].state + ".com"'
card:
type: entities
entities:
- type: weblink
url: ${URL}
What the person could not manage to achieve is accessing that “window.location.href” data - but which custom card do have an access? ))
tekker
(fff)
December 20, 2022, 12:00pm
673
how to get iframe card to take up whole screen in panel mode?
looks like its a bug.
tekker
(fff)
December 20, 2022, 1:12pm
675
yea but now put it in config-template-card… now it doesnt take up the whole screen if its narrow.
Resize your browser and see.
petro
(Petro)
December 20, 2022, 1:17pm
676
put it in a vertical or horizontal stack. I’m sure there’s way’s to get around it.
Do you man this?
But try playing with “aspect_ratio”:
tekker
(fff)
December 20, 2022, 1:20pm
678
yes this is what i mean, how do you put aspect_ratio in config-template-card?
This is an option of “iframe” card:
tekker
(fff)
December 20, 2022, 1:22pm
680
oh my god i need some sleep… thank you so much , i cant believe this slipped by me
I am stuck with templated entities
My variables are a list of entities. How can I inject them into my entities?
Here’s what I have now but without luck.
variables:
- entity: sensor.socket_wireless_power_watt
- entity: sensor.socket_christmass_tree_power
entities: ${vars.map(v => v.entity)}
