šŸ“ 100% Templatable Lovelace Configurations
I want to show image based on nane of a template.
I try many different times, this format work in devo tools but showing nothing.
I donā€™t understand if i can use this mod
type: picture
image: /local/{{ states('input_text.prova') }}.jpg
tap_action:
action: none
hold_action:
action: none
Read docs on Github, there are examples there.
Basically - whatever you use, you should read a manual first before using.
In short: your templates are written in jinjia, but this card accepts templates written in JS.
Must be smth like this:
type: custom:config-template-card
entities:
card:
  type: picture
  image: '${ your js code here }'
Also - please check this (not related to our issue, but anyway):
tap_action:
action: none
hold_action:
action: none
There are some problems with indents.
I read a lot but for me itā€™s not very simply.
I made this but didnā€™t work
entities:
  - input_text.prova
card:
  type: picture
  image: /local/'${ states('input_text.prova') }'.jpg
  tap_action:
    action: none
  hold_action:
    action: none
  1. Still you are using jinjia. There is no such a thing as ā€œstates(ā€˜input_text.provaā€™)ā€. Use ā€œstates[ā€˜input_text.provaā€™].stateā€.
  2. You cannot place template inside some string (at least in the ā€œofficialā€ version of this custom card). The whole value must be a template, like
image: '${ "some_static_text"  + some js code +  "some_static_text" }'
Again - learn examples on GitHub.
Sorry but Iā€™m not software maker, maybe 20 years ago, and now there is little time for learn and the brain is like steel.
I did this and doesnā€™t work
entities:
  - input_text.prova
card:
  type: picture
  image: /local/'${ states[ā€˜input_text.provaā€™].state. }'.jpg
  tap_action:
    action: none
  hold_action:
    action: none
No problem, this is what the Community for).
Please check this:
image: '${ "/local/" + states["input_text.prova"].state + ".jpg" }'
or (same):
image: >-
Yes but not all itā€™s of the same thinking.
Thanks to much, first code finally working.
This is only a first try, this evening I have to put as a background image in a very long picture element
Thanks so much, my 250 lines of picture element is fully working!
I want to show value of the entity used in a history-graph card. Originally, the card has this code:
type: history-graph
show_names: false
entities:
  - entity: sensor.gas_consumption
title: Daily Gas Consumption (mĀ³)
I want to change the title to Daily Gas Consumption (xxx mĀ³) , where xxx = the value of the entity sensor.gas_consumption.
How do I do that with? Tried this code below, but it was not correct.
type: history-graph
show_names: false
entities:
  - type: 'custom:config-template-card'
    entities:
    variables:
      gas_value: sensor.gas_consumption
title: Daily Gas Consumption (${gas_value} mĀ³)
Tried this below, no error, but no graph.
entities:
variables:
  - GAS_VALUE: states['sensor.gas_consumption'].state
card:
  type: history-graph
  show_names: false
  entities:
  title: Daily Gas Consumption (${GAS_VALUE} mĀ³)
Almost ā€¦ Any idea?
Finally! I made it :slight_smile:
Whatever that was, I canā€™t use ā€œvariable nameā€. This works.
Too bad, I cannot escape colon character.
Iā€™m having trouble changing icons based on sensors with more than one state.
For an on/off sensor this works to change icon based on state:
variables:
  SHELLY_STATE: states['switch.shelly_pump_control'].state
entities:
  - switch.shelly_pump_control
card:
  type: entities
  entities:
    - entity: switch.shelly_pump_control
      icon: '${SHELLY_STATE === ''on'' ? ''mdi:power'' : ''mdi:power-off''}'
But I have a sensor ( a TRV / climate sensor) with four states: Idle, Off, Heat & ERROR and Iā€™d like to change the icon based on the state of the sensor. I tried this and variations of it - but Iā€™m basically guessing (unsuccessfully) at the correct syntax:
variables:
  TRV03_STATE: states['sensor.trv_03_status'].state
entities:
  - switch.trv_03
card:
  type: entities
  entities:
    - entity: switch.trv_03
      icon: >-
        {% if '${TRV03_STATE === ''ERROR'' ? ''mdi:alert-circle''}' %}
        {% elif '${TRV03_STATE === ''Off'' ? ''mdi:power-off''}' %}
        {% elif '${TRV03_STATE === ''Idle'' ? ''mdi:sleep''}' %}
        {% elif '${TRV03_STATE === ''Heat'' ? ''mdi:fire''}' %}
        {% else %}
        {% endif %}
Iā€™ve blindly tried a bunch of other stuff - but nothing that gets me closer to a solution. Any ideas or nudges in the right direction appreciated and welcome.
You are using a mix of jinjia code and ā€œ${}ā€ code.
You should only use JS code inside ā€œ${}ā€. Scroll up a bit, find an example with a weblink. It does not have conditions ā€œif then elseā€, add them by yourself - using JS.
Thanks @Ildar_Gabdullin - I was pretty sure I was doing something fundamentally wrong. I couldnā€™t find any examples dealing with icon change on multiple states. I did play with this kind of syntax:
But I basically just donā€™t know what Iā€™m doing - not even enough to google solutions :confused:
You can place JS code here:
icon: >-
Thanks @Ildar_Gabdullin Iā€™m afraid I donā€™t know what JS code is :confused: Iā€™m proficient at copy / paste and very little else. I tried this following your suggestion, but I have no idea why itā€™s wrong:
entities:
  - sensor.s1_circulation_pump_onoff
card:
  type: entities
  entities:
    - entity: sensor.s1_circulation_pump_onoff
      icon: >-
        {% if is_state('sensor.s1_circulation_pump_onoff', '1') %}
        mdi:lightning-bolt-circle
        {% else %} mdi:lightning-bolt-outline
        {% endif %}
I appreciate this must be frustrating to watch ā€¦
4 methods:
type: vertical-stack
cards:
  - type: custom:config-template-card
    entities:
      - sensor.processor_use
    card:
      type: entities
      entities:
        - entity: sensor.processor_use
          icon: |-
              if (parseFloat(states['sensor.processor_use'].state) >= 50)
                'mdi:car';
              else
                'mdi:account';
  - type: entities
    entities:
        entities:
        row:
          icon: |-
                'mdi:car';
              else
                'mdi:account';
  - type: entities
    entities:
      - type: custom:template-entity-row
        icon: |-
          {% if states(config.entity)|int >= 50 -%}
            mdi:car
          {%- else -%}
            mdi:account
          {%- endif %}
  - type: entities
    entities:
        card_mod:
          style: |
            :host {
              {% if states(config.entity)|int >= 50 %}
                --card-mod-icon: mdi:car;
              {% else %}
                --card-mod-icon: mdi:account;
              {% endif %}
ŠøŠ·Š¾Š±Ń€Š°Š¶ŠµŠ½ŠøŠµ
Awesome, thanks for your patience with me - thereā€™s no way Iā€™d have got there without working examples to start with - I really appreciate your help
Hereā€™s what worked for me eventually (I got caught out not knowing the difference between ā€˜else ifā€™ and ā€˜elifā€™). Thanks again for your help @Ildar_Gabdullin
- entity: switch.trv_02
  icon: |-
        if ((states['sensor.trv_02_status'].state) == 'ERROR')
          'mdi:alert-circle';
        else if ((states['sensor.trv_02_status'].state) == 'Off')
          'mdi:mdi:power-off';
        else if ((states['sensor.trv_02_status'].state) == 'Idle')
          'mdi:sleep';
        else if ((states['sensor.trv_02_status'].state) == 'Heat')
          'mdi:fire';
        else
          'mdi:help-circle-outline';
Thank you for posting a working template. Here is a test template I just worked on that does a few things that werenā€™t working for you. Noticeably it uses named variables and I was able to escape the character colon : by surrounding it with backslashes \
This template is fully working (for me at least); Iā€™m just posting it here in case it can help someone else. I find the original documentation could use a few more to demonstrate how certain things can be done.
entities:
  - light.bathroom
variables:
  STATE: states['light.bathroom'].state
  LABEL: ('The bathroom light is ' + states['light.bathroom'].state)
card:
  type: light
  entity: light.bathroom
  name: ${'This\:\ ' + LABEL}
