📝 100% Templatable Lovelace Configurations
sure, that is cool.
and yes, it would most definitely be way more efficient to change the names in the UI. Try and avoid as much templating as possible.
It’s a bit of a trend with all of these mushroom cards and the likes, for people to not realize templating comes at a cost. Some more than others. My experience with this card is that it’s very heavy for the system, and should only be use if cant be avoided. Even though it’s using Javascript, which is handled in the frontend.
Its a magic card, but use it wisely…
shouldnt it be:
replace(' Hue', '')
? or are all of your lights in the Wohnzimmer :wink:
another thought could be to not use the integration name in the entity_id/friendly_name at all. We can find those in modern day templates with {{integration_entities('hue')}} or per area {{area_entities('wohnzimmer')}}, so taking out the integration name there would be even more functional, in that you could use the same entity_id (which would be the slugified) name…
Can anyone help me? I can’t seem to get this to work. I want to set dynamic segments. The static ones work. Just not the templates ones.
Suggestions?
type: custom:config-template-card
variables:
  BB-Temp-Min: states['input_number.basement_bedroom_temp_min'].state
  BB-Temp-Max: states['input_number.basement_bedroom_temp_max'].state
entities:
  - sensor.ewelink_th01_temperature
card:
  type: gauge
  entity: sensor.ewelink_th01_temperature
  needle: true
  segments:
      color: '#db4437'
      color: orange
(untested) try renaming these vars.
Also, (just a guess too) try converting a string value (which a state is) to int.
It was the variable names.
Apparently it doesn’t like (-) hyphens
Well, in many languages names cannot include “-”.
So I got the variable name issue solved.
But now my final segment isn’t working.
I’ve tried adding 2 to the max variable. And I’ve tried creating a new variable and adding 2 to it.
But it just overrides the BBTempMax segment.
variables:
  BBTempMin: states['input_number.basement_bedroom_temp_min'].state
  BBTempMax: states['input_number.basement_bedroom_temp_max'].state
  BBTempMax2: states['input_number.basement_bedroom_temp_max'].state + 2
entities:
card:
  type: gauge
  needle: true
  min: 5
  max: 30
  segments:
      color: '#db4437'
      color: orange
      color: '#43a047'
      color: orange
      color: '#db4437'
I suggest to use Entities card for learning how CTC (config-template-card) works.
  - type: custom:config-template-card
    variables:
      INPUT_NUMBER: states['input_number.test_number']
    entities:
      - ${INPUT_NUMBER.entity_id}
    card:
      type: entities
      entities:
        - entity: ${INPUT_NUMBER.entity_id}
        - entity: sun.sun
        - entity: sun.sun
This is a simple example.
Add whatever you want to test for variables’ values & then you may check their results in “name” labels.
I have the following 2 cards that work OK:
       - type: conditional
         conditions:
           - entity: timer.{{ entity }}_on_duration_timer
             state_not: 'idle'
           - entity: input_boolean.ui_show_timer_bar_or_time
             state: 'on'
         elements:
           - type: custom:timer-bar-card
             entity: timer.on_duration_timer
             layout: full_row
             text_width: 0%
             style:
               left: {{ left }}%
               top: {{ top + timer_top_offset }}%
               transform: 'translate(-50%, -50%) scale(1.5, 1)'
       - type: conditional
         conditions:
             state_not: 'idle'
             state: 'off'
         elements:
             layout: full_row
             text_width: 100%
             style:
               left: {{ left }}%
               transform: 'translate(-50%, -50%) scale(1, 1)'
I am trying to consolidate them into 1 card using config-template-card but get a “No card configured” error.
      - type: 'custom:config-template-card'
        variables:
          SHOW_BAR: states['input_boolean.ui_show_timer_bar_or_time'].state
        entities:
          - input_boolean.ui_show_timer_bar_or_time
        card:
          type: conditional
          conditions:
              state_not: 'idle'
              state: "${ SHOW_BAR }"
          elements:
              layout: full_row
              text_width: "${ SHOW_BAR === 'on' ? '0%' : '100%' }"
              style:
                left: 53%
                top: 33.5%
What am I missing?
This is NOT a card, this is an element inside picture-elements card, it is not supposed to be used elsewhere.
If you need to use a conditional card inside CTC - use a CONDITIONAL CARD, not a conditional element.
OK so I changed the code to the following and now it works:
      - type: conditional
        conditions:
          - entity: timer.on_duration_timer
            state_not: 'idle'
        elements:
            variables:
            entities:
            card:
              layout: full_row
            style:
              left: 53%
              top: 33.5%
              transform: "${ SHOW_BAR === 'on' ? 'translate(-50%, -50%) scale(1.5, 1)' : 'translate(-50%, -50%) scale(1, 1)' }"
Or you may put a conditional CARD inside CTC, and add CTC as an element - if you need to use variables inside conditions.
what is my problem?
i have installed the frontend.
I d like to have the secondary info for the multiple row entities, but cannot get that working. no idea what i am missing. i cpied exactly the code. can you confirm it still works? yes i have card-mod installed
Post a final code what you tried to use.
But if it is not about using config-template-card - better to discuss it in the source thread.
HI guys, have a question that have me scratching my head,
i have this template that pulls info from the kodi Sensor integrations:
but the results of my sensors when i load Home assistant dont match
Sesnors:
########### Home Cinema Sensors KODI  ###########
    sensors:
      kodi_recently_movies_data:
        friendly_name: "Kodi Movies data"
        icon_template: mdi:movie-roll
        value_template:  "{{ state_attr('sensor.kodi_recently_added_movies', 'data') }}"
    sensors:
      kodi_recently_movies_1:
        friendly_name: "Kodi Movie 1"
        value_template:  "{{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[2] }}"
    sensors:
      kodi_recently_movies_2:
        friendly_name: "Kodi Movie 2"
        value_template:  "{{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[3] }}"
    sensors:
      kodi_recently_movies_3:
        friendly_name: "Kodi Movie 3"
        value_template:  "{{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[4] }}"
    sensors:
      kodi_recently_movies_4:
        friendly_name: "Kodi Movie 4"
        value_template:  "{{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[5] }}"
    sensors:
      kodi_recently_movies_5:
        friendly_name: "Kodi Movie 5"
        value_template:  "{{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[6] }}"
my end goal is to extract the poster part.
any help on why this is happening would be very appreciated!
thanks all
Quick edit:
It seams that the only thing i need is to wait for the first sensor to obtain its data, is there a way i can delay or force refresh a template sensor after x amount of time?
here i refined the template a bit:
Kodi sensors for:
Poster
{{ state_attr(‘sensor.kodi_recently_added_movies’, ‘data’).split(’{’)[9].split(‘poster": "’)[1].split(’"},’)[0]}}
Name
{{ state_attr(‘sensor.kodi_recently_added_movies’, ‘data’).split(’{’)[9].split(’“title”: “’)[1].split(’”,’)[0]}}
Fanart
{{ state_attr(‘sensor.kodi_recently_added_movies’, ‘data’).split(’{’)[9].split(‘fanart": "’)[1].split(’"},’)[0]}}
Trying to have a short mp4 clip in my dashboard and found this post. Where exactly would I store this? tried configuration.yaml but that is not accepted.
So you edit your dashboard (3 vertical dots); “+ Add Card” ; Select the “Webpage” card; Select “Show code editor”, then enter this code there.
Do not include the beginning “card:” as that is a given when adding a new card this way.
Thanks! Highly appreciated!! :grinning:
Hi all,
Quick question, i got this sensors that work fine from 1 to 5 but 6 and 7 shows unavailable.
##Movie 1
    sensors:
        friendly_name: "Kodi Movie 1 Poster"
        value_template: >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[2].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_name_1:
        friendly_name: "Kodi Movie 1 name"
        value_template: >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[2].split('"title": "')[1].split('",')[0]}}
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[3].split('poster": "')[1].split('"},')[0]}}
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[4].split('poster": "')[1].split('"},')[0]}}
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[5].split('poster": "')[1].split('"},')[0]}}
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[6].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_6:
        friendly_name: "Kodi Movie 6"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[7].split('poster": "')[1].split('"},')[0]}}
      kodi_recently_movies_7:
        friendly_name: "Kodi Movie 7"
        value_template:  >-
          {{ state_attr('sensor.kodi_recently_added_movies', 'data').split('{')[8].split('poster": "')[1].split('"},')[0]}}
the information exist
so why is it limiting me to 5 sensors?
Thank you all
How is this related to config-template-card?
