i did the same thing for plex, now i change to kodi and trying it.
Im having trouble with adding the config-template-card
Ive managed to get the section working but Im trying to add it so that both the grid cards use the same config-template-card or is this not possible.
Here is a section of the code, it seams that its because the config-template-card only supports card and not cards.
kiosk_mode:
non_admin_settings:
kiosk: true
- title: Temp
path: temperatures
layout:
width: 962
height: 601
icon: ''
badges: []
type: custom:grid-layout
cards:
- type: grid
cards:
- type: custom:config-template-card
variables:
apex_min_temp: parseFloat(states["input_number.graph_min_temp"].state)
apex_max_temp: parseFloat(states["input_number.graph_max_temp"].state)
entities:
- input_number.graph_min_temp
- input_number.graph_max_temp
card:
- type: custom:apexcharts-card
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Lounge
show_states: true
colorize_states: true
experimental:
color_threshold: true
series:
- name: ' '
stroke_width: 2
show:
header_color_threshold: true
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.l_temperature
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
min: ${apex_min_temp}
max: ${apex_max_temp}
forceNiceScale: true
now:
show: true
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Dining room temperature
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.dining_room_temperature
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Garden room temperature
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.garden_room_temperature
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Understairs temperature
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.understairs_temperature
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
columns: 4
square: false
- type: grid
cards:
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Bathroom temperature
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.bathroom_temperature
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
min: 15
max: 22
now:
show: true
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Bedroom temperature
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.bedroom_temperature
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
min: 15
max: 22
now:
show: true
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Office temperature
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.office_temperature
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
min: 15
max: 22
now:
show: true
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Outside temperature
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 10
color: blue
- value: 15
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
entity: sensor.live_outside_temp
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
min: 0
max: 22
now:
show: true
columns: 4
square: false
I know the last section for the - type: grid is not aligned yet but this is how far I got after spending hours on working out the code and couldnât find the answer.
Would be grateful for any advice.
You posted 365 line of a code; if you really need a help - suggest you to simplify the issue to as short as possibleâŚ
Sorry I should have explained better:
The code creates 8 Apexcharts on a tablet in landscape with 4 alone the top and 4 underneath, all displaying the temperature in different rooms.
The code works fine but I would like to be able to change the Y axis min and max numbers in each chart using two input_number helpers with the use of the config-templet-card to change the setting instead of changing each entry in all 8 charts i.e.:
Previous settings:
yaxis:
min: 15
max: 22
What I would like:
yaxis:
Iâve managed to get config-template-card to work on one chart:
variables:
entities:
card:
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Lounge
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
But my problem comes in where to place the config_template_card code in my layout to work with all 8 cards.
The structure I have is:
- title:
path:
......etc....
cards:
- type: grid
cards:
title: Lounge
apex_config:
yaxis:
......etc....
# repeated 3 more times across the tablet on 1st row
columns: 4
square: false
- type: grid
cards:
title: Bedroom
apex_config:
yaxis:
......etc....
# repeated 3 more times across the tablet on 2nd row
columns: 4
square: false
Hope this explains it.
The problem I think is because the config-template-card only supports card and not cards but I donât know whether there is a work around as the documents mention about âDefining global functions in variablesâ and âDashboard wide variablesâ but I wasnât sure how to set that up hence now asking for help.
Using CTC for graphs is not a good idea.
Let me show an example.
type: ctc
entities:
- sensor.some_sensor
- input_number.number
card:
type: history-graph
hours_to_show: >-
${ states['input_number.number'].state }
entities:
Here âhours_to_showâ may be changed dynamically.
The card is working properly - but it blinks every time the sensor changes (not to mention a fact that âhistory-graphâ becomes not âstreamlinedâ as w/o CTC).
Now imagine this stack:
type: ctc
entities:
- sensor.some_sensor_1
- sensor.some_sensor_2
card:
type: vertical-stack
cards:
- type: history-graph
hours_to_show: >-
entities:
hours_to_show: >-
entities:
Here BOTH graphs will be redrawn if ANY sensor changes (i.e. blinking more frequently).
(do not bother that I am not using variables here, not related to the âblinkingâ issue)
Now closer to your particular case.
- You have not defined sensors in the âentitiesâ section of CTC. Means - graphs will not be updated automatically on these sensorsâ change. But if you would define - then see what was written above about blinking.
- If you still want to have MIN & MAX values defined dynamically - consider using 8 CTC for each graph (ofc each sensor must be defined inside âentitiesâ). Do not bother about repeated âvariablesâ section - this may be reduced either by using yaml anchors (if you use yaml mode for a dashboard) OR by using global CTC variables.
Check this (untested):
title: My dashboard
config_template_card_vars:
HOURS_TO_SHOW: states['input_number.number'].state
cards:
- type: grid or whatever
cards:
- type: ctc
entities:
card:
type: history-graph
hours_to_show: >-
${ HOURS_TO_SHOW }
entities:
- type: ctc
entities:
card:
type: history-graph
hours_to_show: >-
${ HOURS_TO_SHOW }
entities:
Thank you for your help, the variables will only be changed 4 times a year on each season really just to make the graphs more readable.
After your help I was looking to set up the Dashboard wide variables, This is how far Iâve got but its not working
- title: Test1
path: test1
badges: []
cards:
entities:
card:
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Lounge
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
Iâve also tried placing the variables before views as in the docâs but still not working:
- title: Test1
path: test1
badges: []
cards:
entities:
card:
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Lounge
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
Whereas this works fine:
- title: test
path: test
subview: false
badges: []
cards:
variables:
entities:
card:
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Lounge
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
Cracked it after reading the docs again after so many times it clicked.
Though I had but still not working.
- parseFloat(states["input_number.graph_min_temp"].state)
- parseFloat(states["input_number.graph_max_temp"].state)
- title: Test1
path: test1
badges: []
cards:
entities:
card:
apex_config:
yaxis:
min: ${vars[0]}
max: ${vars[1]}
Thanks again.
I checked my code, it is correct.
Here this is meaningless:
- title: Test1
path: test1
badges: []
cards:
entities:
because you need to declare variables ONCE on a âdashboard levelâ.
And on a âdashboard levelâ you are using âvars[âŚ]â notation (list), on a wrong âview levelâ - ânameâ notation (dict) - and then calling these vars by namesâŚ
Also, I see no need in using parseFloat here since you are not doing any math.
Sorry this is a result of copying and passing bits of code into the forum and not checking before posting.
In my running code I hadnât tried to declare them twice, it was either way Iâd been testing and getting nowhere.
I have to use parseFloat as the values for min and max need to be returned as numbers, they wonât except strings.
Ill have another look to see if I can work it out.
OK, come back with a feedback.
The code I posted earlier MUST work.
As for parseFloat - these values ARE strings:
option_1: abc
option_2: 123
and they are converted internally properly.
Check my example for âhours_to_showâ.
OK thanks.
This is from the docs from Apexcharts
I couldnât get this working on one apexchart until I looked up how to convert from string to number in the CTC docs and that corrected it. If I change min and max to a fixed number and put that in inverted commas it doesnât work.
Surely you should not put number in commas.
And commas are not added here too:
hours_to_show: >-
Finally got this working as is:
title: home
- title: Temp
path: temperatures
cards:
variables:
entities:
card:
type: grid
cards:
apex_config:
yaxis:
....... repeated 3 more times
columns: 4
square: false
variables:
entities:
card:
type: grid
cards:
apex_config:
yaxis:
columns: 4
square: false
Tried without parseFloat and it wouldnât work, min and max need an integer.
I also tried creating âDashboard wide variablesâ but could not get it to work, I searched and couldnât find anywhere anyone else has used config_template_card_vars: in their code.
This guy has some examples on his blog of âconfig_template_card_varsâ [CARD] Config Template Card to boost your dashboards in Home Assistant FR â ArminasTV (domoplus.eu)
Thanks for that, thatâs the only one Ive seen and Ive checked mine against it but mine still doesnât work for some reason.
A working code is provided here
So I wonder what could be not working in your case.
It does frustrate me when there seems no apparent reason. Rather than playing around in the UI I created a yaml file for the dashboard and thatâs where Iâve been experimenting. Here is my attempt at creating a âDashboard wide variableâ as I understand it for 1 card to test but it docent work:
title: YAML Sandbox
- title: Temperature
path: temperature
icon: mdi:thermometer
theme: backend-selected
cards:
entities:
card:
graph_span: 16h
hours_12: true
span:
start: day
offset: +6h
header:
show: true
title: Lounge
show_states: true
experimental:
series:
- name: ' '
stroke_width: 2
show:
color_threshold:
- value: 15
color: blue
- value: 19
color: green
- value: 20
color: yellow
- value: 24
color: red
fill_raw: last
curve: smooth
extend_to: false
apex_config:
tooltip:
enabled: false
legend:
show: false
yaxis:
now:
show: true
Would love to know why? It must be something simple, but Iâm buggered if I can find it.
Let us simplify the issue a bit.
Use Entities card instead of apexcharts.
Assume the card has 2 rows (sun.sun).
Use these two variables for ânameâ options.
See if it works.
I am proposing this since not everyone using apexcharts.
Righto, I couldnât quite work out what you meant but found this further up the post so copied it over:
This works ok:
title: YAML Sandbox2
# config_template_card_vars:
# Sun: states["sun.sun"]
variables:
entities:
- ${Sun.entity_id}
card:
type: entities
entities:
- entity: ${Sun.entity_id}
- entity: sun.sun
And this doesnât, displaying no card at all:
# variables:
entities:
- ${Sun.entity_id}
card:
type: entities
entities:
- entity: sun.sun
Fine, will analyze the problem in 2 days.
