šŸ“ 100% Templatable Lovelace Configurations
wow thatā€™s very nice. Very nice indeed, and exactly what I was looking for. In the Frontend that is.
But what unreadable, and difficult to debug config file is this going to be, if we need to do that for all entities. Nested Custom cards, modders, what have you, and each entity having its own templateā€¦and several cards having their own way of more or less supporting templates, some Jinja, some CSS, and of course JSā€¦
This is ever going to be an interface for the broader public is rather unlikely, and, tbh, it is getting much more difficult by the weekā€¦:wink:
Donā€™t get me wrong, I really really need these templates and option to do so, but feel we should get back to the devā€™s (or need we say STAFF now) and ask if this canā€™t be included in the native architecture. reintroduce Customize, or custom-ui even (which still works btw, but was never officially supported)
The devs at this point are pretty much me and balloobā€¦need more bodies
I donā€™t get it, this still doesnā€™t workā€¦
Does it make any difference that I have a split Lovelace config over several !include files?
title: Test View
cards:
  - type: custom:compact-custom-header
  - type: 'custom:config-template-card'
    config:
      type: custom:hui-entities-card
      title: TESTING
      entities:
        - entity: switch.hall_light
          icon: "${states['switch.hall_light'].state === 'on' ? 'mdi:music' : 'mdi:sleep'}"
followed by more cards
Something is attempting to be rendered because I get a slight card misalignment where this card should be.
Trying to use this to show a WiFi link count for a sonoff switchā€¦
In the template editor (dev-tools) this shows the number:
{{state_attr(ā€˜sensor.sonoff1_2914_statusā€™ ,ā€˜WiFi LinkCountā€™)}}
Iā€™ve tried this:
    config:
      type: 'custom:hui-entity-card'
      entities:
        - entity: sensor.sonoff1_2914_status
But itā€™s just blank. Is there any way I can display this or do I just need to create template sensors?
custom:hui-entities-card not entity
Iā€™ve been doing all my testing in storage mode, canā€™t think of what could make a difference as in the end the front end just has the full configuration. Search the .js file for the console.log statements. Uncomment those and see if there is anything strange being output. I was able to do your exact example, just switching out the entity for mine, without issue.
You sure you donā€™t have any errors in your browser console?
Still blankā€¦
config:
  type: 'custom:hui-entities-card'
  entities:
      name: "${states.sensor.sonoff1_2914_status.attributes['WiFi LinkCount']}"
Those strings show the correct value in the template editorā€¦
I didnā€™t look closely enough at your previous post after seeing the entity thing. This is not like the template editor, this is just Javascript. The states object has each entity on it, so you need to access it appropriately "${states['sensor.sonoff1_2914_status'].attributes['WiFi LinkCount']}"
Ah!!! Thought I tried thatā€¦
Now:
Can I make it show the description as well as the state?
config:
  entities:
      name: "${states['sensor.sonoff1_2914_status'].attributes['WiFi LinkCount']}"
I donā€™t know what description you are referring to
Iā€™d like the icon, text like MQTT Disconnects and then the number (1 in this case)
Similar for WiFi Disconnects. The graphic as I posted it doesnā€™t show much useful information to see what it is showingā€¦ Basically a description on each line for what it is showing.
I have 2 cards at the moment:
Iā€™d love to just have one and show the MQTT & Wifi info for each switchā€¦
The state is just the RSSI and the MQTT and WiFi are attributes of that entity.
So Iā€™m down to this now:
            config:
              title: MQTT & Wifi Connections
              show_header_toggle: false
              entities:
                - sensor.sonoff1_2914_status
                - sensor.sonoff2_3110_status
                - entity: sensor.sonoff2_3110_status
                  name: "${states['sensor.sonoff2_3110_status'].attributes['WiFi LinkCount']}"
                - sensor.sonoff5_1083_status
                - entity: sensor.sonoff5_1083_status
                  name: "${states['sensor.sonoff5_1083_status'].attributes['WiFi LinkCount']}"
                - sensor.sonoff6_3719_status
                - entity: sensor.sonoff6_3719_status
                  name: "${states['sensor.sonoff6_3719_status'].attributes['WiFi LinkCount']}"
Still ugly, duplicates the RSSI on all 3 lines and I canā€™t tell it itā€™s displaying MQTT or WiFiā€¦ so if I could get rid of the extra RSSIā€™s and label the MQTT and Wifi that would be perfectā€¦
OK how about thisā€¦
            config:
              entities:
                  name: "${'Coffee MQTT ' + states['sensor.sonoff1_2914_status'].attributes['MqttCount'] + ' WiFi ' + states['sensor.sonoff1_2914_status'].attributes['WiFi LinkCount']}"
                  name: "${'Toothbrush MQTT ' + states['sensor.sonoff2_3110_status'].attributes['MqttCount'] + ' WiFi ' + states['sensor.sonoff2_3110_status'].attributes['WiFi LinkCount']}"
                  name: "${'Garage MQTT ' + states['sensor.sonoff5_1083_status'].attributes['MqttCount'] + ' WiFi ' + states['sensor.sonoff5_1083_status'].attributes['WiFi LinkCount']}"
                  name: "${'Alarm MQTT ' + states['sensor.sonoff6_3719_status'].attributes['MqttCount'] + ' WiFi ' + states['sensor.sonoff6_3719_status'].attributes['WiFi LinkCount']}"
Great card and I learned a bunch. Thanks @iantrich
Any way to line up the MQTT and Wifi over to the right a bit? It seems to ignore spacing
&nbsp maybe?
not sure how to add thoseā€¦ it goes blank if I add here
"${'Garage &nbsp MQTT ā€™ + states
"${ā€˜Garageā€™ + &nbsp + 'MQTT ā€™ + states
"${ā€˜Garageā€™ + ā€˜&nbspā€™ + ā€™ MQTT ā€™ + states
any other ways I can do that?
ā€¦
Sometimes the 10 character minimum allowed length of a forum post is kind of anoying, donā€™t you think?
Ok, so yes I do have console errorsā€¦
Just to be clear, with this config, the button card works but the entities card doesnā€™t:
    config:
      type: 'custom:hui-entity-button-card'
      name: "${this.hass.states['switch.hall_light'].state === 'on' ? 'light is on' : 'Light is off'}"
      icon: "${this.hass.states['switch.hall_light'].state === 'on' ? 'mdi:music' : 'mdi:sleep'}"
    config:
      title: TESTING
      entities:
          name: "${this.hass.states['switch.hall_light'].state === 'on' ? 'light is on' : 'light is off'}"
and this is the console error:
Uncaught (in promise) RangeError: Maximum call stack size exceeded
    at Array.forEach (<anonymous>)
    at HTMLElement._evaluateConfig (config-template-card.js?track=true:2309)
    at Object.entries.forEach.entry (config-template-card.js?track=true:2313)
_enqueueUpdate	@	config-template-card.js?track=true:1838
async function (async)
_enqueueUpdate	@	config-template-card.js?track=true:1824
requestUpdate	@	config-template-card.js?track=true:1809
set	@	config-template-card.js?track=true:1554
setConfig	@	config-template-card.js?track=true:2292
create_card_element_createElement	@	4013522ā€¦.chunk.js:4823
createCardElement	@	4013522ā€¦.chunk.js:4823
createCardElement	@	4013522ā€¦.chunk.js:5614
_rebuildCard	@	4013522ā€¦.chunk.js:5693
element.addEventListener.ev	@	4013522ā€¦.chunk.js:5614
fireEvent	@	app-1011b616.js:966
customElements.whenDefined.then	@	4013522ā€¦.chunk.js:4823
Promise.then (async)
config.cards.forEach	@	4013522ā€¦.chunk.js:5693
_createCards	@	4013522ā€¦.chunk.js:5693
updated	@	4013522ā€¦.chunk.js:5693
performUpdate	@	app-1011b616.js:93
_enqueueUpdate	@	app-1011b616.js:93
requestUpdate	@	app-1011b616.js:93
set	@	app-1011b616.js:93
hui_view_HUIView	@	4013522ā€¦.chunk.js:5614
_selectView	@	4013522ā€¦.chunk.js:5913
updated	@	4013522ā€¦.chunk.js:5913
hui_root_HUIRoot	@	4013522ā€¦.chunk.js:5693
_clone	@	app-1011b616.js:444
_commitTemplateResult	@	app-1011b616.js:215
commit	@	app-1011b616.js:215
render	@	app-1011b616.js:366
shady_render_render	@	app-1011b616.js:81
update	@	app-1011b616.js:127
_fetchConfig	@	4013522ā€¦.chunk.js:5943
firstUpdated	@	4013522ā€¦.chunk.js:5943
ha_panel_lovelace_LovelacePanel	@	4013522ā€¦.chunk.js:5913
loadingProm.then	@	app-1011b616.js:3074
updated	@	app-1011b616.js:3074
update	@	app-1011b616.js:444
_updateHass	@	app-1011b616.js:3137
services	@	app-1011b616.js:3137
n	@	core-671132a8.js:1
(anonymous)	@	core-671132a8.js:1
c	@	core-671132a8.js:1
subscribe	@	core-671132a8.js:1
I	@	core-671132a8.js:1
window.hassConnection.then	@	core-671132a8.js:1
150	@	core-671132a8.js:1
__webpack_require__	@	core-671132a8.js:1
Thanks for your work, great card
Good job @iantrich :tada:
Hi @DavidFW1960 would you mind share the sensor config? I am interested on having those infos too :slight_smile:
Cheers
