šŸ“ 100% Templatable Lovelace Configurations
Youā€™ll likely not see 95% of what is in custom cards in core, ever. But that discussion isnā€™t really for this threadā€¦
Donā€™t know if itā€™s on your side or custom-card-modder. The issue is when applying custom-card-modder to your card it works without errors but after maybe 5 seconds it will lose the custom-card-modder modifications, no error is reported in the log and all works normally just the mod who disappear.
Here is the code
card:
  type: 'custom:config-template-card'
  config:
    entity: sensor.co
    show_card: true
    stroke_width: 20
    fill: 'rgba(100,100,100,0.0)'
    type: 'custom:circle-sensor-card'
    stroke_color: >-
      ${this.hass.states['sensor.co'].state === 'Clear' ? '#55f26e' :
      this.hass.states['sensor.co'].state === 'Warning' ? '#e8e400' : '#d30000'}
style:
  border-radius: 100px
  font-size: 1.1em
  font-weight: bold
  line-height: 1.5
type: 'custom:card-modder'
Thanks for looking into it.
looks like weā€™re in business with lists! :tada:
going to do some actual testing this time and hopefully have a release later tonight :slight_smile: I got excited last night and released it after ~2 minutes of testing :rofl:
Iā€™ll put the config of the above in the Readme as well as it uses all demo platforms and is an easy one to test with
Update: I managed a full 15 minutes of testing before I got distracted :crossed_fingers:
Release 1.0.2
  • Now properly support lists within configurations
  • New template variables introduced to cleanup templates states and user
I wouldnā€™t put the card-modder on my card, put it at the top level of config instead. Iā€™m not really rendering anything. Havenā€™t played with it much, in general actually, to say for sure though.
I still canā€™t get this to workā€¦
  - type: 'custom:config-template-card'
    config:
      type: custom:hui-entities-card
      title: TESTING
      entities:
        - entity: switch.hall_light
          icon: '${states[''switch.hall_light''].state === ''on'' ? ''mdi:music'' : ''mdi:sleep''}'
sure, appreciate that.
my fear is the lovelace-ui.yaml is going to be littered with all these customizations in the cards, where we could use the customize section, and of course the custom-ui in regular Ha to keep things tidy.
imagine needing something like this customize_glob in Lovelace:
sensor.*_motion_sensor_temperature:
  templates:
    icon_color: >
      if (state < -5) return 'rgb(30, 255, 255)';
      if (state < 0) return 'rgb(30, 144, 255)';
      if (state < 10) return 'rgb(255, 255, 0)';
      if (state < 15) return 'rgb(255, 211, 30)';
      if (state < 20) return 'rgb(0, 128, 0)';
      if (state < 25) return 'rgb(255, 165, 0)';
      if (state < 30) return 'rgb(255, 0, 0)';
      if (state < 35) return 'rgb(85, 0, 0)';
      return 'rgb(47, 0, 0)';
just a few lines now, neatly separated from the config itselfā€¦
or maybe an even better example used on 153 states in my instanceā€¦:
automation.*:
  templates:
    icon_color: >
      if (state === 'on') return 'rgb(251, 210, 41)';
      return 'rgb(54, 95, 140)';
I have tested latst version and there mut be something odd going on with the mini-graph-card and second-entity-row because there is nothing wrong in my opinion with the code.
Without the template card it works, with it it doesnā€™t, and to test, I used the example code from git repo
          - type: vertical-stack
            cards:
              - type: horizontal-stack
                cards:
                  - type: custom:config-template-card
                    config:
                      - type: custom:mini-graph-card
                        name: "${states['sensor.dark_sky_temperature'].state > 10 ? 'Cozy' : 'Too Hot/Cold'}"
                        icon: mdi:thermometer
                        more_info: false
                        group: false
                        entities:
                          - sensor.dark_sky_temperature
                        hour24: true
                        show:
                          graph: false
                          icon: true
                          extrema: true
                          fill: false
                        align_state: center
1 Step forward!
I donā€™t have to use ā€œ- type: custom:mini-graph-cardā€
I do have to use ā€œtype: custom:mini-graph-cardā€
Now the odd thing is that is ā€œblinkingā€
And the icon is not loading at all :smiley:
Put double quotes on the outside and single quotes in the inside
icon: "${states['switch.hall_light'].state === 'on' ? 'mdi:music' : 'mdi:sleep'}"
Thatā€™s exactly why balloob didnā€™t want templates in Lovelace :wink:
Iā€™ll play around with it tonight, but my guess is that the show is being botched.
As for the blinking, I was afraid of this happening, especially with things with animations. Pretty much what is happening, is that anytime there is ANY state change, the full card is being redrawn. Perhaps @rhodges idea to have an entity to use could be beneficial in that we would only watch for a state change on that entity. Or perhaps a list of entities to watch for state changes fromā€¦? Will have to ponder on that.
As @iantrich suggested, the card-modder has to be used inside the template card. The following works:
        config:
          style:
            --paper-item-icon-color: "${ parseFloat(states['sensor.dow_futures_change_pct'].state) > 0 ? 'green' : 'red' }"
          card:
            type: 'custom:hui-entities-card'
            title: Stocks
            show_header_toggle: false
            entities:
              - entity: sensor.dow_futures
                icon: "${parseFloat(states['sensor.dow_futures_change_pct'].state) > 0 ? 'mdi:arrow-up-bold-circle' : 'mdi:arrow-down-bold-circle' }"
Thank you for testing i will try it later when my time becomes mine again.
Thanks :slight_smile:
Much appreciated, so far all my tests attempt unfortuantely failed otherwise I would have posted some use examples
Actually, we can even take the combination between card-modder and template card even futher to modify every row in the card. So, for example, you could use:
        config:
          title: Stocks
          entities:
            - type: custom:card-modder
              style:
              card:
                type: custom:hui-sensor-entity-row
              style:
                --paper-item-icon-color: "${ parseFloat(states['sensor.s_p_futures_change_pct'].state) > 0 ? 'green' : 'red' }"
              card:
                entity: sensor.s_p_futures
                icon: "${parseFloat(states['sensor.s_p_futures_change_pct'].state) > 0 ? 'mdi:arrow-up-bold-circle' : 'mdi:arrow-down-bold-circle' }"
And you would get something like:
Basically, every row in the card is using its own style template.
Iā€™m so pumped that we figured this out. Did you know about this @thomasloven? We tried it on a whim
Wow canā€™t wait to get into this thanks a lot!!
A game changer in my opinion
If you really want to go crazy with the template, hereā€™s one that allows different color for the icon based on the current market conditions.
        config:
          title: Stocks Futures
          entities:
              style:
                --paper-item-icon-color: "${var state = parseFloat(states['sensor.dow_futures_change_pct'].state);
                  state < -5 ? 'rgb(151, 26, 30)' :
                  state < -4 ? 'rgb(194, 39, 45)' :
                  state < -3 ? 'rgb(236, 27, 33)' :
                  state < -2 ? 'rgb(244, 101, 35)' :
                  state < -1 ? 'rgb(248, 147, 29)' :
                  state < 0 ? 'rgb(255, 194, 15)' :
                  state < 1 ? 'rgb(202, 219, 43)' :
                  state < 2 ? 'rgb(142, 198, 65)' :
                  state < 3 ? 'rgb(106, 158, 47)' :
                  state < 4 ? 'rgb(37, 145, 60)' : 'rgb(0, 111, 58)'}"
              card:
I am sure there is a better way to do this and would love to hear your thoughts.
Edit: To be clear, as of 1.0.2, this is theoretical and not implemented.
I think an optional temp_var or something might be beneficial in this madness that you have createdā€¦something like:
        config:
          temp_var: "parseFloat(states['sensor.dow_futures_change_pct'].state)"
          entities:
              style:
                --paper-item-icon-color: "${if (temp_var < -5) 'rgb(151, 26, 30)';
                  else if (temp_var < -4) 'rgb(194, 39, 45)';
                  else if (temp_var < -3) 'rgb(236, 27, 33)';
                  else if (temp_var < -2) 'rgb(244, 101, 35)';
                  else if (temp_var < -1) 'rgb(248, 147, 29)';
                  else if (temp_var < 0) 'rgb(255, 194, 15)';
                  else if (temp_var < 1) 'rgb(202, 219, 43)';
                  else if (temp_var < 2) 'rgb(142, 198, 65)';
                  else if (temp_var < 3) 'rgb(106, 158, 47)';
                  else if (temp_var < 4) 'rgb(37, 145, 60)';
                  else 'rgb(0, 111, 58)'}"
              card:
                icon: "${temp_var > 0 ? 'mdi:arrow-up-bold-circle' : 'mdi:arrow-down-bold-circle' }"
