105 new zone editor, can't edit home
I removed my zones and added them in the new zone editor, it’s awesome! i’m curious though why I can’t edit home… home is still set with the single pin under general, so I had to go back to added Home in the configuration.yaml file so I could override the radius that works best. Seems like Home should just be editable here too and then no more zones in configuration.yaml!
It is, it is called “configuration -> general” there you set your home with your location. At least that would be my best gues :wink:
that works, you can move the point, but you cannot modify the radius, or maybe I just missed it
I like to make my radius a little larger and place the point in the center of my small neighborhood, so things go off faster when I pull in, and also, so it doesn’t go on and off when I walk the kids around the circle we have
Can confirm, still need to edit the yaml file to override the default Home zone and be able to change the radius. I tried creating a new “Home” zone with the new editor and restarting HA to see if it would override it and it wouldn’t work.
@dkmcgowan Have you found the solution? I did the same like you and would like to have home zone little bigger :slight_smile:
as long as you create a
zone:
  - name: Home
  - latitude:
  - longitude:
  - radius:
then you overwrite the default one. the name has to be exactly Home, therefore i dont use it, because in dutch i prefer “Thuis”.
