Hi!
I am in the process of building my home alarm system.
Right now i am the part where i need a lout outdoor siren - so that i can scare the potential burglars away - when the alarm triggers.
I havent bought any outdoor siren yet - so ideas are welcome.
My thought was to use a cheap simple siren - like a honeywell - or something from aliexpress.
As far as i can see - most of them use 12volts - and when you give them 12volts - they turn on.
this seems simple.
Are there any compatible 1 way 12volts relay with esp2866 - that can be used in esphome?
My ideea was that i could make it work by the following components
230v AC -> ESPrelay -> Siren/Horn.
I have been looking at this:
It says 5volt - but i am not sure if it will work.
Basically i would like to have as few components as possible - but i am not sure if the relay can “drive” the sirene directly - or if i need an external psu as-well
because - if i dot - then i might aswell utilize one of my exisiting sonoff basic - and simply use it to switch on an old 12volt psu - connected to the sirene?
any reccomendations?
br Ronni
