16 Dec 2020 - Cannot connect to host updater.home-assistant.io:443
Hardware Environment
  • [ x] Raspberry Pi [3B+/4]
  • [ ] ODROID [C2/C4/N2(+)/XU4]
  • [ ] ASUS Tinker [S]
  • [ ] Intel NUC (or compatible)
  • [ ] OVA (Open Virtualization Applicance, on Intel NUC or any other hardware, please add the Hypervisor you are using)
Home Assistant OS release:
  • [x ] Fresh installation of release 5.10
  • [ ] Updated from version x.y
  • Additional information (if accessible):
Supervisor logs:
Journal logs:
Kernel logs:
Description of problem: I had my SD burned, so I write the image of the OS for a new installation and then restore the snapshot.
HA starts, but the HassOS cannot update. Tha date is that one of the release (16Dec2020).
If I change the host’s date, the error desappear, but if I shutdown the host, it comes back to Dec 2020.
Moreover if I reboot or update, it doesn’t.
This is the log:
Logger: homeassistant.components.updater Source: helpers/update_coordinator.py:153 Integration: Updater (documentation, issues) First occurred: December 16, 2020, 6:26:38 PM (1 occurrences) Last logged: December 16, 2020, 6:26:38 PM Error requesting Home Assistant update data: Cannot connect to host updater.home-assistant.io:443 ssl:True [SSLCertVerificationError: (1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate is not yet valid (_ssl.c:1125)')]
This is the info of the system:
`System Health
version: 2021.1.5
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.4.79-v7l
arch: armv7l
timezone: Europe/Rome
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: failed to load: unreachable
host_os: Home Assistant OS 5.10
update_channel: stable
supervisor_version: 2021.01.7
docker_version: 19.03.13
disk_total: 57.8 GB
disk_used: 5.7 GB
healthy: true
supported: true
board: rpi4
supervisor_api: ok
version_api: ok
installed_addons: Duck DNS (1.12.4), Samba share (9.3.0), Terminal & SSH (8.10.0), NGINX Home Assistant SSL proxy (3.0.1), File editor (5.2.0), Check Home Assistant configuration (3.6.0), AppDaemon 4 (0.3.1), ESPHome (1.15.3), Log Viewer (0.9.0), Mosquitto broker (5.1), Network UPS Tools (0.3.1), Zigbee2mqtt (1.16.1), zigbee2mqtt-edge (test), RTL_433 to MQTT Bridge (0.2)
dashboards: 1
mode: storage
resources: 2`
