It’s the 2nd time in a few days I get some stange message from an internal ip address which isn’t mine.
it’s the 172.30 range.
I use 192 for local and 10.x for vpn, never do I use 172.30
is HA using this somehow interally.
the messages I get are:
and in the observer
22-02-15 21:47:50 ERROR (MainThread) [supervisor.api.ingress] Ingress error: Cannot connect to host 172.30.32.1:62661 ssl:default [Connect call failed (‘172.30.32.1’, 62661)]
22-02-15 22:00:27 ERROR (MainThread) [supervisor.homeassistant.api] Error on call https://172.30.32.1:8123/api/config:
22-02-15 22:00:27 WARNING (MainThread) [supervisor.misc.tasks] Watchdog miss API response
is this something HA uses internally? or should I be worried someone has compromised my system?
for as far as I know this is a private ip range so it can’t come from outside.
