cruizalonso
(César Ruiz Alonso)
October 25, 2023, 3:59pm
1
Good evening,
I have bought the blinds switch called “1CH WiFi Curtain Module CB2S.” When I connect it to the Tuya app, it connects without any issues.
However, in Home Assistant, it shows as “unsupported.” Is there anything that I can do to make the controller work in Home Assistant?
AnthonyDet
(Anthony DET)
November 4, 2023, 11:12am
2
Hello same problem here with :
1CH Wi-Fi Curtain Module (unsupported)
Do you finded an solution ?
dadoef
(Dadoef)
January 11, 2024, 12:27pm
3
I experience the same problem. The device works with Google Home and other assistants but shows as unsupported in Home Assistant.
I found integration: Tuya / 1CH WiFi Curtain Module CB2S unsupported · Issue #103491 · home-assistant/core · GitHub but there seems no action so far.
Same here. Any Clue anyone? Or is there already a workaround?
great
i have the same problem and found this page
Open source firmware (Tasmota/Esphome replacement) for BK7231T, BK7231N, BL2028N, T34, XR809, W800/W801, W600/W601 and BL602 - openshwprojects/OpenBK7231T_App
