Has anyone managed to integrate the door opener from 1Control
Any solution found ? I have the same need…
Sorry no solution here, but just would like to take this one up I m also considering this solution, but without homeassistant, it would not do it
Bumping this up, is there still no integration for this one ?
Hi all ! Has anyone found a way to integrate it ?
Hi all, Also interested
I’ve messaged 1Control in order to get some access or api documentation. If they open this up, I’ll probably dev the extension for HA as I need it for my setup too. I’ll keep this thread updated.
If anyone has found an api or a way to get around let me know
Good news, apparently they are openning an http api in january. This means we’ll be able to fetch data and communicate with solo link.
Here’s the answer I got from them:
we are working on a new firmware for the LINK with API support.
We will release it as an OTA update in january
this firmware will allow you to control SOLO through LINK using http API.
Cordiali Saluti - Best Regards
Hi, did you get any news since then?
no news???
Yes,
I couldn’t write as this website was on read only for some time. But I got back in touch with them early February and got this reply from them:
The API implementation is still in the testing stage, I will contact you personally as soon as its gets released.
I’ll keep this thread updated. I’m planning on purchasing 1control solo as soon as they release the API and will work on a open source home assistant integration.
Regards
I think you’ll need the 1control link as well so it connects to the cloud, the solo enables control through bluetooth only
I have the combo (solo + link) already and IT knowledge so let me know if I can be of any help.
Hello everyone, isn’t there a way to connect directly with BT? The Raspy would have BT available.
Yep, I’m getting the Link too.
I’ll set up a github as soon as I get access to the API. I have little expectations on having webhooks so most probably we’ll be pooling the api.
Regards
Fine!
I wait news
Here is another update:
No news. I’ll message them back in 2 weeks, they said it was in QA so hopefully we get something soon !
Regards
Here is now an official statement from 1Control - should be available in the second half of 2024:
Thanks for sharing,
I just found zigbee garage door openers for 20$ that integrate with HA, I didn’t even know those existed and they work perfectly. As my only need is to be integrated with HA I’m out
Godspeed
Any News on that? Second half of 2024 is nearly passing away.
Now the release date has been pushed back a whole year to the second half of 2025. By then there will probably be two competing providers with even greater compatibility, hopefully. This announced functionality would be the icing on the cake in my smart home environment. Does anyone know of any alternatives or a workaround?
