2022.8.5 is on the way out the door now
HA 2022.8.5 Eve Weather attempt. This one throws another error when prompted for pin.
Looking through logs I’ve noticed hci1 and hci0. Is it a hardcoded message for hci0?
2022-08-16 07:16:57.355 DEBUG (MainThread) [bleak.backends.bluezdbus.client] _cleanup_all(/org/bluez/hci1/dev_D8_04_6F_5C_55_5A)
2022-08-16 07:16:57.355 DEBUG (MainThread) [bleak.backends.bluezdbus.client] already disconnected (/org/bluez/hci1/dev_D8_04_6F_5C_55_5A)
2022-08-16 07:16:57.355 DEBUG (MainThread) [bleak.backends.bluezdbus.client] Connecting to device @ D8:04:6F:5C:55:5A with hci0
Thats interesting as the error is the aiohomekit version that comes with 2022.8.4. 2022.8.5 should have included the update to aiohomekit 1.2.11 whereas your log looks like its still running 1.2.6
2022-08-16 07:17:03.662 DEBUG (MainThread) [aiohomekit.controller.ble.client] Bleak error calling <function BleDiscovery.async_start_pairing at 0x7f8aadeeacb0>, retrying...
File "/config/deps/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py", line 62, in _async_wrap
return await func(*args, **kwargs)
File "/config/deps/lib/python3.10/site-packages/aiohomekit/controller/ble/discovery.py", line 126, in async_start_pairing
salt, pub_key = await self._async_start_pairing(alias)
File "/config/deps/lib/python3.10/site-packages/aiohomekit/controller/ble/discovery.py", line 109, in _async_start_pairing
ff_char = self.client.get_characteristic(
File "/config/deps/lib/python3.10/site-packages/aiohomekit/controller/ble/bleak.py", line 31, in get_characteristic
char = self.services.get_service(service_type).get_characteristic(
AttributeError: 'NoneType' object has no attribute 'get_characteristic'
1.2.6 which comes with 2022.8.4 which matches up with the erorr in your log.
1.2.11 which comes with 2022.8.5
Damn! Somehow I had a pip install of an old version in /config/deps.
Anyway success!!!
Eve room 2022.8.5
https://controlc.com/1b017fea
Thank you for your hard work!
Eve Thermo gen1 works too.
Eve Weather throws an error before pin prompt.
File “/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py”, line 502, in async_step_pair
self.finish_pairing = await discovery.async_start_pairing(self.hkid)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 65, in _async_wrap
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/discovery.py”, line 137, in async_start_pairing
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/discovery.py”, line 119, in _async_start_pairing
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/bleak.py”, line 37, in get_characteristic
raise ValueError(
ValueError: Service 00000055-0000-1000-8000-0026BB765291 not found, available services: []
Thanks!
It works!
Same error for Eve Outlet
raise ValueError(
/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/client.py:461: UserWarning: Using default MTU value. Call _acquire_mtu() or set _mtu_size first to avoid this warning.
warnings.warn(
2022-08-16 10:55:32.406 ERROR (MainThread) [homeassistant.components.homekit_controller.config_flow] Pairing attempt failed with an unhandled exception
raise ValueError(
success with 1st gen Eve Room! Thank you!
that said, besides creating a template sensor, is there a way to round the value shown by even room (right now it has 13 decimals)?
and also, how can I get the temperature and humidity to update (no changes since my last HA restart).
it updated 2 minutes ago after not moving for 2 hours… not sure why it’s not updating more often… must be something with sensor accuracy.
The service not found problem is currently unfixable since it’s happening deep in the Linux bluez stack. If you are running ha on macOS the problem doesn’t happen. Realistically it’s not going to get fixed on Linux any time soon unless someone has an in with the bluez devs. Probably better off waiting until we have remote Bluetooth support and putting an esp device close to it to act as a relay but we are months away from that as no code has been written for that yet.
how to interpret the air quality coming from the Eve Home? it was 0 at first, switcher to 0.98 and shortly after to 1. It has been sitting on 1 since then.
0 Unknown
1 Excellent
2 Good
3 Fair
4 Inferior
5 Poor
With 2022.8.6 I have this error popping up with Eve Room and Eve Thermo. Even the paired devices throw this error when I want to change heating mode for ex.
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/discovery.py”, line 124, in _async_start_pairing
ff_raw = await char_read(self.client, None, None, ff_char, ff_iid)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 276, in char_read
pdu_status, data = await ble_request(
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 138, in ble_request
await _write_pdu(client, encryption_key, opcode, handle, iid, data, tid)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 156, in _write_pdu
for data in encode_pdu(opcode, tid, iid, data, fragment_size):
File “/usr/local/lib/python3.10/site-packages/aiohomekit/pdu.py”, line 72, in encode_pdu
retval = STRUCT_BBBH.pack(0, opcode.value, tid, iid)
struct.error: required argument is not an integer
Please open an issue for that. It’s not clear from the trace what’s going wrong.
Hello, I use 5 Eve Thermo and 3 Energy 1st generation. At first it was not possible to connect them, but after the latest updates the first generation works for one device … then when I try to connect another device I get an error:
An error occurred while pairing with this device. This may be a temporary storage or your device may not be supported at the moment.
(Sorry this is a translation)
This is the same error I got before.
So it look like the old generation can connect but only 1 device.
Is there a solution for this?
Logger: homeassistant.components.homekit_controller.config_flow
Source: components/homekit_controller/config_flow.py:479
Integration: HomeKit Controller (documentation, issues)
First occurred: 21:32:48 (3 occurrences)
Last logged: 21:48:28
Traceback (most recent call last): File “/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py”, line 479, in async_step_pair self.finish_pairing = await discovery.async_start_pairing(self.hkid) File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 76, in _async_wrap return await func(*args, **kwargs) File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/discovery.py”, line 139, in async_start_pairing salt, pub_key = await self._async_start_pairing(alias) File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/discovery.py”, line 121, in _async_start_pairing ff_char = self.client.get_characteristic( File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/bleak.py”, line 89, in get_characteristic raise ValueError( ValueError: Service 00000055-0000-1000-8000-0026BB765291 not found, available services: []
