This is probably an Amazon issue and not a HA issue but I’m looking for your experiences and tips.
I have a Xiaomi Robot Vacuum integrated via Home Assistant. I have to say “Alexa, start the vacuum” twice as the first time almost always gets me “the device doesn’t support that”, but the second, exactly same command usually works. Sometimes this takes several tries.
It’s the same whether I use this as a direct command, or if I create a routine that listens for “Alexa, start the vacuum” and then turns it on. I can use other commands but my OCD brain wants this to work - it’s annoying.
The vacuum always starts when invoked via the Xiaomi app or the Home Assistant interface, so it’s probably not an issue with the integration or the vacuum itself. There’s nothing relevant in HA log.
Any tips?
