2/3 plus 1/3 horizontal layout using layout-card
Can anyone drop below working yaml for the awesome layout-card that can show two other cards, one limited to 2/3 of the available width and a second to the right of it limited to 1/3?
I have it working to show 2 columns, but I can’t get specific width % to work.
something like:
type: custom:grid-layout
layout:
  grid-template-columns: 1fr 2fr
  grid-template-rows: auto
  grid-template-areas: |
    "left right"
cards:
  - type: vertical-stack
    view_layout:
      grid-area: left
    cards:
    view_layout:
      grid-area: right
    cards:
the 1fr 2fr means a 1:2 ratio between the columns.
You can name your columns anything you like - I have used left an d right in this example.
Thanks, unfortunately I get nothing shown (no errors either, though) with this:
layout:
    "left right"
cards:
    view_layout:
      grid-area: left
    cards:
      - type: markdown
        content: Left Test
    view_layout:
      grid-area: right
    cards:
      - type: markdown
        content: Right Test
Hmm, it’s should work. My Mac is installing an update right now so cannot double check it,
I’ll try in an hour.
Edit: quick question, exactly where are you pasting this? Are you using the UI and pasting there? …the version I gave you is for the whole page, not an individual card within a page.
Thanks again, that may explain why I wasn’t seeing anything then, as I had put this in a manual card.
As I need these two cards to sit in a conditional card eventually.
OK, so try this (note the difference in type and the addition of layout_type)
- type: custom:layout-card
  layout_type: custom:grid-layout
  layout:
      "left right"
  cards:
      view_layout:
        grid-area: left
      cards:
        - type: markdown
          content: Left Test
      view_layout:
        grid-area: right
      cards:
        - type: markdown
          content: Right Test
Brilliant, that’s working perfectly. Many thanks again, appreciate the quick help.
No worries! :+1:
Please consider marking my post with the solution tag. This places a check-mark next it which lets others know that this topic has been resolved and helps others find answers to similar questions.
