2 automation - 1 switch
Hi all. There are two automations controlling one switch. If in the first automation the temperature is out of range, the switch is turned on. But if the humidity is normal, then the humidity automation turns off this switch. And vice versa. How to make it so that if the service of the first automation worked, then the service of the second automation stopped working?
  - alias: auto_cold
    - platform: homeassistant
      event: start
    - platform: state
      entity_id:
      - sensor.average_sensor_temp
      service: >-
         {% set hi = states('input_number.temp_on_cold') | float %}
         {% set low = states('input_number.temp_off_cold') | float %}
         {% set temp = states('sensor.average_sensor_temp') | float %}
         {% if temp > hi and states('switch.vent_out') == 'off' %}
           switch.turn_on
         {% elif temp < low %}
           switch.turn_off
         {% endif %}
      entity_id: switch.vent_out
  - alias: auto_dehumid
      event: start
    - platform: state
      entity_id:
      - sensor.average_sensor_humid
      service: >-
         {% set hi = states('input_number.humid_on_dehumid') | float %}
         {% set low = states('input_number.humid_off_dehumid') | float %}
         {% set humid = states('sensor.average_sensor_humid') | float %}
         {% if humid > hi and states('switch.vent_out') == 'off' %}
           switch.turn_on
         {% elif humid < low %}
           switch.turn_off
         {% endif %}
