Team,
Would it be possible to place 2 cards on top of eachother?
Use case:
An overview of temperatures where I can clearly see the outside temperature (trend). Besides knowing the outside temp it’s great to see if it’s getting warmer or colder.
Shown here:
4 column grid card, with 4 vertical-stacks, each containing 3 button-cards
photoshopped on top of a sensor card
Thinking about this “on top of” could also be “very very close below”.
When “on top of” the text may have to be adjusted to keep it readable.
You can try it within picture elemnt card, placing cards as elements in the same spot. Eventually using grid layout card and put the cards into the same cell… Just a thougths, not sure if this will work. Ah, probably also you will need to use card mod to make background of at least one card transparrent…
It might depend on cards used; I tried this in the past (do not recall what cards used, though) and it was causing clipping of card content on the card border .
