NortonLR
(Norton Lr)
April 12, 2023, 2:10pm
1
I have two Apex cards that both show the same temperature (template) entity.
The buitentemp temperature shown on both cards is not the same.
What is the cause of that?
####### sensor.yaml
sensors:
#garage sensors aanpassen
buitentemp_garage_ds18b20_gecorrigeerd:
friendly_name: "Buitentemp garagedak (corr)"
unit_of_measurement: °C
value_template: "{{ (states ('sensor.buitentemperatuur_ds18b20')| float - 1.8) | round(1) }}"
unique_id: buitentemp_garage_ds18b20_gecorrigeerd
jchh
((not John))
April 12, 2023, 2:20pm
2
can you provide the yaml for both cards?
NortonLR
(Norton Lr)
April 12, 2023, 2:26pm
3
top card:
type: custom:apexcharts-card
experimental:
color_threshold: true
graph_span: 24h
apex_config:
yaxis:
- id: first
forceNiceScale: true
decimalsInFloat: 0
opposite: true
labels:
show: true
style:
colors: red
- id: second
forceNiceScale: false
decimalsInFloat: 1
opposite: false
labels:
show: true
style:
colors: lightblue
- id: third
decimalsInFloat: 0
opposite: true
labels:
show: true
style:
colors: green
show:
last_updated: true
header:
standard_format: false
show: true
show_states: true
colorize_states: true
title: Elga Watt vs Temp buiten
span:
end: hour
series:
- entity: sensor.elga_aanvoertemp_ds18b20_gecorrigeerd
type: line
group_by:
func: last
duration: 15m
stroke_width: 2
color: red
- entity: sensor.smart_plug_elga_power
type: line
float_precision: 3
group_by:
func: last
duration: 15m
stroke_width: 2
- entity: sensor.buitentemp_garage_ds18b20_gecorrigeerd
type: line
group_by:
func: last
duration: 15m
stroke_width: 3
color: green
bottom card:
graph_span: 24h
span:
end: hour
header:
show: true
show_states: true
title: Gasverbruik laatste 24 uur
apex_config:
yaxis:
- id: first
decimalsInFloat: 3
opposite: false
labels:
show: true
style:
colors: orange
- id: second
decimalsInFloat: 1
opposite: true
labels:
show: true
style:
colors: green
- id: third
decimalsInFloat: 1
opposite: true
labels:
show: true
style:
colors: yellow
series:
- entity: sensor.gasusage_this_hour
unit: m3
type: column
color: '#EF810E'
group_by:
func: max
show:
datalabels: false
extremas: false
unit: °C
type: line
stroke_width: 3
color: green
group_by:
func: max
show:
datalabels: false
extremas: false
- entity: sensor.temp_hum_woonkamer_temperature
unit: °C
type: line
stroke_width: 3
color: yellow
group_by:
func: max
show:
datalabels: false
extremas: false
jchh
((not John))
April 12, 2023, 2:28pm
4
I think it is this causing the slightly different results:
group_by:
func: last
duration: 15m
and
group_by:
func: max
NortonLR
(Norton Lr)
April 12, 2023, 2:46pm
5
Thank you,
I 'll make them both the same and wait for the result
NortonLR
(Norton Lr)
April 12, 2023, 2:51pm
6
They are now the same .
Thank you for the prompt solution.
