Hello, I would like to know how it is possible to use 2 GPS mobile app trackers for the same user, I use two mobile phones, one for work and the other when I do sports, and the idea would be that when I go with one and leave the other at home, it does not appear always at home when it is not. I have already tried to do it by disabling the wifi to avoid being always connected and thus recognize that you are at home. But although the log of the mobile that I have taken if the status of the different locations has changed, the identity of the person has always marked Home.
any suggestions to fix this? it is possible to use two devices, should you leave one off in flight mode for example ??
OK, so I understand that if I leave one of the phones at home, connected to the WIFI and it does not go into sleep mode and is always connected, it will be predominant over the other and therefore it will always mark HOME, so the idea is when leaving disable WIFI so that the mobile that determines the location is the one that moves, but of course one of the two will always mark HOME.
It is not very clear to me where I should configure the consider_home
