I hit my 75 device limit on Lutron and bought another smart hub. I plugged it in, created a new home on Lutron app, and I’m able to switch seamlessly between hubs in the app and control things.
The new hub was also discovered by Home assistant So I proceeded to add the new device. IT added and I had to press the black button on the back and then it dissapeared from HA completly. I can not see it in the integrations, none of the new devices are shown. The initial maxed hub is still available and working properly. I can also still see and control both hubs on my phone with no issues.
Scheppy , I know your post is old, but did you ever resolve the visibility of two caseta hubs in HA?
Answered my own question by simply trying.
Added a second hub, and the integration discovered it. Then I pressed the button, and all devices on the second hub are in my HA instance.
cdemots, how this the two-hub integration into HA working? Is it reliable? I am building a new home and will likely go with Lutron, but will certainly hit the 75 unit limit.
I’ve been running SmartThings for years. Recently did a renovation and added a Lutron system with 80+ devices. Figured I could just run two Lutron hubs, but SmartThings will only recognize one.
I also have a bunch of other smarthome stuff, zwave smart locks, outlets, sensors, Sonos stuff etc etc. Excited to make this leap to HA.
