I don’t know if it’s because the bluetooth proxy is too far or they’re sharing sensor IDs (they shouldn’t, they’re tagged differently) but every so often 1 of them (bedroom or living room) returns unknown values and I have to manually unplug the unknown one and replug.
Is there something I am missing? They both use package includes with variables to define each. Like so. the LD2410c.yaml is basic and is a copy of what is suggested in ESPhome.
Example Below for bedroom-pres-and-bt.yaml
substitutions:
friendly_name: Bedroom Pres and BT
device_id: bedroom_pres_and_bt
ld2410_id: "2"
api_key: "xxx"
ota_pass: "xxx"
static_ip: "141"
packages:
common: !include common/common.yaml
# manual_ip: !include common/manual-ip.yaml
bt_proxy: !include common/bluetooth-proxy.yaml
ld2410c: !include common/ld2410c.yaml
logger:
level: INFO
# logs:
# sensor.ld2410: NONE
baud_rate: 0
