i’m looking for a 2 pipe system fan coil thermostat.
I currently have a MIDEA system with the following thermostat:
I found Fan Coil Thermostat - Heatmiser neoStat-HC
and
hysen Central Air Conditioning 3 Speed FCU WIFI Thermostat
Unfortunately Hysen is shipping from China and will take forever + unknown customs and they mention that the integration is broken.
The heatmiser one needs a hub as well (which I’m not really hyped about having something extra for 3 fan coil controllers only) and it seems that there isn’t a home assistant integration either.
Does anyone have a product that they are currently using and know that it works with home assistant and google assistant?
FYI: I used Tuya and Smart Life.
Initially the instructions said to use Smart RM but this is not supported apparented by Tuya integration. The tweak that I had to do was to go to the settings and change the divider to 10 as initially my temperature was reported for example as 255 C instead of 25.5 C
I picked up the thermostat you suggested and integrated it into the home assistant. the problem, that in the tuya app I can manage everything, heat, cold, speed, temperature, in the home assistant, instead only temperature and on off., how did you solve it ???
Are you using a thermostat card?
Because if you are not using a thermostat card you will not be getting those controls.
Here it is how it looks for me:
Also I had to go into Tuya integration and select the devices to configure. Then I configured them like below:
The reason for the above was because it would display:
265 C instead of 26.5 C
It’s pure a display issue and you probably need to configure it also if you are using F instead of C.
Yes. i am using thermostat board, but as i see, you also don’t have all the controls. I would like to be able to adjust the speeds, the cooling or heating mode, etc.
Oh I see what you mean.
Yes - it seems Tuya has only Auto and Off modes.
That’s how I use it - I have 2 pipe system - not 4 pipe to have it automatically switch between hot/cold.
There is new integration now. I have 2-pipe system so it switches now pretty much to Heat/Cool.
I don’t know if someone has configured it with 4-pipe - if the new integration will have more options.
