hey, I Need help with skyconnect and z2m
Well, after a lot of deliberation, I switched yesterday from CONBEE2 to SKYCONNCET with Z2M, it was nice, it took about 7 hours to transfer everything, it seems nice so far, the transfer was overall all right, most devices connected without a problem, but there were some that I had to fight with for a few minutes, each Case, I feel a lot less stable for some reason, already 3 sensors that I set stable from the Z2M so I set just disappeared from the Z2M but I hope it’s not something that will happen regularly because then this whole transition is worth nothing, in any case I have 2 repeaters connected. I’m attaching a picture, in MAP it seems like it can’t stretch these lines through the repeaters, it worked for me at first, at some point when I configured all the devices the line with the LQI just disappeared and since then it doesn’t work
I paird 2 aqara fp1 presence sensor , It detects presence but as soon as there is no presence it stays stuck on TRUE state
If I refresh the setting manually (attach a picture) in Z2M it updates the state, but why is it like this? I want it to go from TRUE to FALSE automatically
I dont want to go back to conbee2 with DeConz
Thank you!
