2 RFlink Gateways possible?
Hi @ all,
is it possible to use 2 Different RFlink Gateways on the same host?
I want to use one for all my 433,92MHz Devices and one 433,42MHz for my Somfy RTS Shutters.
Both are connected via USB.
But i don’t know if it is possible to use 2 gateways and if it would be possible how to config ?
Did someone try that ?
I have exactly the same setup, 433,92 for doorbell, sensor etc… and “old” somfy with 433,42Mhz, so I have bought two rflink, and two esp, and now I have a mqtt <-> 433.X for each frequencies…
I don’t remember if it’s:
or
Work really well. And don’t need USB to raspi anymore, only 5V power supply.
I also use 2 RFLink gateway devices.
It works well with Domoticz but HA can only send commands to one gateway.
It seems to be impossible to send commands to both RLink gateways at the same time :frowning:
I think ill stay with Domoticz :slight_smile:
I have also circumvented this problem with a Python script and MQTT.
Only not with ESP8266 this gave an unstable result
